Screaming whining/spooling/spinning sound on decelerate
Old Jan 27, 2019 | 03:26 PM
xsports33's Avatar
Default Screaming whining/spooling/spinning sound on decelerate
hey guys. I haven't posted in a while. 4 kids later and a couple moves around the world things have finally settled down a bit.
I'm getting this very weird loud almost spooling like sound (whining, spinning sound) when i'm decelerating or taking my foot of the gas. it happens in all gears and at all speeds. it's almost like when my engine goes into a "deep" vacuum it starts making that spooling/spinning sound. I've checked all the connections, nothing is loose, no CEL, nothing obvious under the hood or under the truck. Specs of the truck in my sig
it happened when i was driving down a mountain. i was coasting down the mountain and in vacuum for a couple seconds, then all of a sudden i started to hear a loud spooling/spinning sound coming from the engine compartment. this has never happened before, and i've never experienced it in any of my vehicles.
any help would be great.i'll try to paste a link to a video i captured when it happens. you can watch the RPM meter drop, then all of a sudden you hear the sound. If i give it a little gas, it goes away immediately, pause a second and it comes back on decelerate.you can hear it from seconds 7-11 then 13- 16, and again from 22-24.
here's the link:
Old Jan 29, 2019 | 06:47 AM
ILuvJDM's Avatar
Almost sounds like a fan rubbing the shroud, do you have mechanical fans or electric?
Old Jan 29, 2019 | 08:10 AM
arthursc2's Avatar
If the PCV system is clogged or not opening, you're absolutely correct about the vacuum.
The engine is pulling a ton of vac and the air is getting sucked in past the main seals, most likely
take the oil cap off next time you hear it, if it stops found the problem.
Or replace the pcv valve and try again
Old Feb 2, 2019 | 03:44 PM
xsports33's Avatar
thanks for the replies! i thought it was the bypass actuator for the supercharger. I ordered a new one from Magnuson, but i installed it and it sound it still there. so $220 dollars later, the problem still exists.
however, i did notice by chance when i put the truck in 4WD that the sound goes away completely. just to double check i coasted down a hill in 4WD no sound, put in 4wd and the sound immediately came back. so i'm guessing Transfer Case... maybe front Diff?
Old Feb 4, 2019 | 10:26 PM
MikeGyver's Avatar
I listened over and over again on my TV with an excellent sound system. To me it sounds like pulling a long wire rope across the edge of a steel table.
Old Feb 5, 2019 | 10:48 AM
arthursc2's Avatar
how is that info going to help the OP?
Old Feb 6, 2019 | 07:35 AM
MikeGyver's Avatar
I guess it won't be helpful unless he has access to professional audio recording equipment. Because of the way phones record audio, almost all of these "listen to this" videos have sound that seems to emphasize everything except what the people who post them want us to hear. I thought my description might help others realize that it is a sound in their truck that they have heard before, too.
Tibbys96Z
Nov 2, 2016 12:48 PM
skaffy03
Oct 23, 2014 05:31 PM
ss408truck
Oct 23, 2010 05:23 AM
03GMC
Apr 15, 2008 11:52 AM
moregrip
237
Jul 2, 2005 10:20 AM
