safe RPM's
Old Jun 23, 2005 | 06:13 AM
sd155racer's Avatar
Originally Posted by Tiburon
That is right..I would aldo consider some titianium retainers with what you just mentioned.
And a new tranny
Old Jun 23, 2005 | 06:20 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by Tractionless
So for example... if I were to put a huge cam in my engine and just change the pushrods, springs, and rod bolts, I could shift the engine at around 6800 rpms? How much rpm would the stock internals withstand?
You are correct like tiburon said titanium retainers those will help. Dont bother with aftermarket rockers they arent worth it. The crank is good for about 7000 rpm rods are the main thing you have to worry about. If you really want to spin one that high then get an lq9 they have better rods and will handle the high rpm better.
Old Jun 27, 2005 | 09:04 PM
2bseen's Avatar
11 Second Truck Club
I have mine set at 6500 now and thinking of going to 6600 or 6700 but I have a built motor.
Old Jun 27, 2005 | 09:14 PM
blacksheep's Avatar
I shifted my stock lq9 at 6800 with a 200 shot, I would not recomend that but 6200-6400 should be fine.
Old Jun 27, 2005 | 09:27 PM
litreddevil's Avatar
Banned
Yes you need to change out rod bolts and pushrods they start to bend at 6200. If it were me I would set the rev limiter to 6100 just to be safe oyu arent going to gain much by adding an extra 100rpm.
i have never bent a push rod and my motors have seen 7000 and 7400.
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
turbo6c3
Oct 5, 2015 06:11 PM
Velocity1
Oct 2, 2015 08:01 AM
carid
Oct 1, 2015 09:22 AM
