Running the Valves after cam install?
Old Jan 18, 2009 | 10:37 PM
Default Running the Valves after cam install?
Do you have to run the valves after installing a cam and springs?
Old Jan 19, 2009 | 08:37 AM
WillPewter2000's Avatar
nope.
Old Jan 20, 2009 | 05:11 PM
Thanks.
Old Jan 23, 2009 | 10:38 PM
I was under the impression that you did because you were changing springs. Any other opinions anyone?
Old Jan 24, 2009 | 05:22 AM
wkdivr's Avatar
The stock rockers are non adjustable. Put some loctite on the bolts, and torque them to (I THINK) 22ft lbs. What I did, is turn the engine over till both valves are on the base of the cam, (just like adjusting them to a certain clearance), then tighten those 2 bolts, then move to the next. It's not really necessary, but you're not torquing em down against spring pressure. Double check my torque numbers, though, as it's been awhile since I did mine.
Old Jan 24, 2009 | 11:10 AM
budhayes3's Avatar
PT's Slowest Truck
The purpose of running in the cam is to get an even wear pattern between the cam and flat tappet lifters. If you have a GENIII engine (99+ NBS), you have roller lifters and there's no need to worry. I would however get a few heat cycles into the valve springs before romping on it, or you could end up with a broken spring. I don't romp on a cold engine in general.
Old Jan 24, 2009 | 01:12 PM
Ok. Thanks guys. Is there anything else that I need to worry about that I might run into?
Old Jan 24, 2009 | 01:23 PM
wkdivr's Avatar
You're gonna be amazed how easy cam swaps are on these LS style engines!!!
Old Jan 24, 2009 | 09:26 PM
Does anyone have the proper torque numbers?
Old Jan 25, 2009 | 05:34 AM
Grumpy5.3's Avatar
He was right, it is 22 ft lbs.
