Running the Valves after cam install?
The stock rockers are non adjustable. Put some loctite on the bolts, and torque them to (I THINK) 22ft lbs. What I did, is turn the engine over till both valves are on the base of the cam, (just like adjusting them to a certain clearance), then tighten those 2 bolts, then move to the next. It's not really necessary, but you're not torquing em down against spring pressure. Double check my torque numbers, though, as it's been awhile since I did mine.
The purpose of running in the cam is to get an even wear pattern between the cam and flat tappet lifters. If you have a GENIII engine (99+ NBS), you have roller lifters and there's no need to worry. I would however get a few heat cycles into the valve springs before romping on it, or you could end up with a broken spring. I don't romp on a cold engine in general.
