ROTORS
Old Jun 7, 2002 | 06:42 PM
00 silver toy's Avatar
Default ROTORS
MY ROTORS ON FRONT ARE RUST BAD (STOCK) SO LOOKING FOR AFTER MARKET ONE
WHAT YOU GUYS LIKE AND WHERE TO GET
INFO IS ALLWAYS GREAT FROM YOU GUYS
THE BEST GROUP AROUND BY FAR
THANKS
CHAD
Old Jun 7, 2002 | 08:18 PM
GREGGO's Avatar
Default Re: ROTORS
No-one has done a rotor swap to my knowledge on the trucks yet other than a show truck or two. I don't understand how they are rusting though. The pads should keep them clean. You might look into having them turned. Other than that, Check Tbyrne (brake rotor link here) , he has great service and products.
Old Jun 7, 2002 | 08:27 PM
GMC SKI's Avatar
Default Re: ROTORS
I've done some new rotors from a company Called KVR they are cross drilled rotors and you can get they dipped in silver gold or black finish to keep they from rusting.
i was told that they used brembo rotors that they drilled out or something like that.
they also make a carbon fiber pad to go with them
with my 99 sierra ext cab they helped me stop alot faster than stock they where as i remember like 1200 canadain bucks for front and rear rotors and pads complete
cheap if you convert in USD dollar
Old Jun 7, 2002 | 08:33 PM
Default Re: ROTORS
yes i tock them off today going to cut them down sat after work
rust lip on iner top and bottom more then you would think on a newer truck
hope i dont go below run out
thanks guys
.J.
20
Mar 4, 2016 03:03 PM
cousblake11
Sep 9, 2015 06:52 PM
Alco
Sep 4, 2015 04:08 PM
