Rollermaster timing chain problem ?????
Old May 1, 2004 | 03:08 PM
Default Rollermaster timing chain problem ?????
I am installing a roller master timing chain. the problem is the new crank gear pulley in the kit slides on by hand all the way and usually you have to tap them into place the last little bit. Is the the way these are made or did i get a bad crank gear.
Old May 1, 2004 | 06:33 PM
bump, anyone
Old May 1, 2004 | 09:02 PM
OBXMarine's Avatar
Hmm, are you using an ASP Crank Pulley? I think they need to be modified a bit. There was a recent post about this. I'll post it if I run across it.
Old May 1, 2004 | 10:11 PM
Are you sure you got the right one? Is it possible to get the wrong one?
Old May 2, 2004 | 01:59 AM
according to the box it is a 1140, which is the one i assume is for the SS's. It lines up properly, and looks totally fine. It just doesn't press on to the crank. I have it totally installed already and just tightened that crap out of the balancer bolt, so it shouldn't go anywhere. I guess i will see how it runs
Old May 2, 2004 | 02:02 AM
sleepersilverado's Avatar
i personly would not be happy with that. that is not correct and i think you should get a diffrent gear.
Old May 2, 2004 | 02:10 AM
Believe me i am not happy either, but really don't have a choice at this point.
Old May 3, 2004 | 05:21 AM
ididit's Avatar
I just got one from More performance 4 a 00 5.3 p/n cs1160/43447
I've not installed it yet..
5.3Okasai
Mar 9, 2022 01:07 PM
03chevytruck
Nov 7, 2016 04:43 PM
The_W
Oct 28, 2015 09:00 PM
chevyl33
Aug 24, 2015 08:21 AM
Ammadien
Jul 22, 2015 08:50 PM
