rocker question
Old Feb 7, 2010 | 05:53 PM
edzo12's Avatar
Default rocker question
i have a cam with .535 lift and i was wondering if i could run 1.8 rockers eith that cam. anybody know if that is safe to run
Old Feb 7, 2010 | 06:23 PM
Mrgoodwrench3's Avatar
I am going to be installing a cam in my 2007 5.3 LY5 next month. I have chosen a Comp Cam that has .534 lift, with the 1.8 rockers it will be .567. I called Comp Cams technical assistance Friday and they advised it would be fine. Not only do you get the extra lift but you will get 1-1.5 degrees more duration.
Old Feb 8, 2010 | 10:01 AM
edzo12's Avatar
sounds good to me. anybody else want to chime in?
Old Feb 8, 2010 | 11:24 AM
budhayes3's Avatar
PT's Slowest Truck
What are the rest of the specs on the cam and who manufactured it? As long as the lobes aren't too agressive, you will be fine. More than likely, with lift that small, you'll be OK with the 1.8 rockers. I'd only go with the bigger rockers if you already have them though, or have a line on a cheap used set or something. For the price of new rockers, you can just get a new cam with more lift and sell the cam you already have which will help offset the price of the new cam
Old Feb 8, 2010 | 11:50 AM
edzo12's Avatar
very true but its alot easier to swap rockers than the cam. the specs are 216/220 .525 .535 114lsa
Old Feb 8, 2010 | 07:33 PM
12 Second Club
You can also get the comp upgrade kit to make your stock rockers more reliable. If you want roller rockers though...I like the HS and YTs. I am thinking of getting some YT 1.8 for my burb just because it has a 100k on it.
Old Feb 8, 2010 | 08:35 PM
budhayes3's Avatar
PT's Slowest Truck
That's a Comp cam correct? You'll be fine with 1.8 rockers...as a matter of fact, on Thunder Racing's website they list that cam and have a note that it "likes higher rocker ratios"...
Old Feb 9, 2010 | 07:04 AM
edzo12's Avatar
sounds good. so that should put my lift over .56x which means that the yellow springs are out the door correct?
Old Feb 9, 2010 | 07:10 AM
Burgundy&TanMan's Avatar
I have run LS6 springs (yellow springs) with a comp XR265 hi lift before and never had a problem and I think it had around the same max lift as you will have. But do whatever makes you happy, were always on a budget around here. It had .558/.563 lift but thats just my .02 worth.
Old Feb 9, 2010 | 09:16 AM
edzo12's Avatar
i hear you on the tight budget part. i have heard those springs are good to 550 and other people say 560 so i dont know what the story is.
