which rocker arms to get
Old Sep 21, 2009 | 06:58 PM
ou812sm's Avatar
Default which rocker arms to get
which rocker arms to get . it's going into a 6.0 with this cam 222/218 .578/.578 112 LSA or i'm keeping my 4.8 and getting this cam 218/214 .578/.578 114 LSA i i want a rocker arm that will last and will do it fuction correctly whats the best rocker arms for an ls engine
Old Sep 21, 2009 | 07:18 PM
Mr. Sandog's Avatar
Stockers. No reason to do otherwise unless you want to do the pin mod.
Old Sep 21, 2009 | 07:23 PM
andrew383's Avatar
traveling mod
stock
Old Sep 21, 2009 | 08:55 PM
nonnieselman's Avatar
stockers are made to last unless you just like spending money..get some of them pretty ones.
Old Sep 21, 2009 | 09:13 PM
dirt track racer 81's Avatar
im still rockin the stockers.. if you get some get those shiny ones that are expensive..
Old Sep 21, 2009 | 09:35 PM
Mangled03gmc's Avatar
Baltimore Whore
Stockers. FTW
Old Sep 21, 2009 | 10:06 PM
jschrock's Avatar
I'll be rockin the stockers til it croaks
Old Sep 21, 2009 | 11:14 PM
built408's Avatar
I would do the Harland Sharp redone stockers.
Old Sep 22, 2009 | 11:19 AM
TVI's Avatar
TVI
Comp Cams also has a trunion upgrade kit for the stock rockers:
http://www.compcams.com/information/...yID=1508422545
Old Sep 22, 2009 | 11:22 AM
BlackGMC's Avatar
Resident Retard
I have a question about this. If you look at alot of the build threads from other members where one of the sponsers built the motor they have roller rockers... So my question is why would our sponsers build a motor with roller rockers and most of the "self-builders" recommend stockers... Not trying to start a pissing match just a simple observation...
