Rocker arm question
Wearin' da big hat
When I pulled my valve cover the other day to check and make sure I didn't have a broken valvespring (having alot of valvetrain noise), I didn't see any broken, but I did notice that some of the rocker arms had some play in them. They move left to right, not up, down, in, or out. I torqued them all down to spec and used locktyte. Is it normal for the rocker arms to have side to side play in them? Btw, the bolts holding them all down are still very tight.
Heres a pic of what I mean, and where it is moving. It is only moving a little bit, but I am thinking this might be where my valvetrain noise is coming from, unless it is bad lifters.
Is this normal?
Is this normal?
That's a picture of an LS7 head. They don't use pedestals, the rocker arm pivot sits on a saddle machined into the head. You can also see the valve stem cap on the titanium intake valve to keep it from mushrooming.
