Rocker arm question
Old Feb 27, 2009 | 12:06 AM
00ChevyScott's Avatar
Wearin' da big hat
Default Rocker arm question
When I pulled my valve cover the other day to check and make sure I didn't have a broken valvespring (having alot of valvetrain noise), I didn't see any broken, but I did notice that some of the rocker arms had some play in them. They move left to right, not up, down, in, or out. I torqued them all down to spec and used locktyte. Is it normal for the rocker arms to have side to side play in them? Btw, the bolts holding them all down are still very tight.
Heres a pic of what I mean, and where it is moving. It is only moving a little bit, but I am thinking this might be where my valvetrain noise is coming from, unless it is bad lifters.
Is this normal?
Old Feb 27, 2009 | 06:14 AM
CashDudeHomie's Avatar
Yes, mine moved the same way, even when tightened. I'm sure there is a maximum movement spec, but I don't know it.
Old Feb 27, 2009 | 06:18 AM
GMCtrk's Avatar
you may want to try a 7.425" pushrod if you aren't using one now. That's what comp recommends.
Old Feb 27, 2009 | 07:02 AM
budhayes3's Avatar
PT's Slowest Truck
Yes, there will be some side to side movement in the rockers, that's OK
Old Feb 27, 2009 | 07:51 AM
Tootall's Avatar
Is it just me . . . but I can't see the rocker stand?
Old Feb 27, 2009 | 08:04 AM
JakeBrakeIH's Avatar
+1...maybe its the camera angle but it looks like its not there...
Old Feb 27, 2009 | 08:30 AM
budhayes3's Avatar
PT's Slowest Truck
Good call, I didn't even notice at first, I don't see it either...
Old Feb 27, 2009 | 08:43 AM
Wearin' da big hat
Thats a picture off of google btw, not my truck. Just used it to show what i was talking about. Thanks for the replies guys.
Old Feb 27, 2009 | 08:45 AM
SBChvy's Avatar
+1 I think you may be missing something. Not installing the rocker pedestal would definitely cause them to be loose and be extremely audible.
Edit:
Just read your other post
Old Feb 27, 2009 | 06:56 PM
Just Enough's Avatar
That's a picture of an LS7 head. They don't use pedestals, the rocker arm pivot sits on a saddle machined into the head. You can also see the valve stem cap on the titanium intake valve to keep it from mushrooming.
