Rings are blown, 6.0 time need help
Old Apr 25, 2004 | 06:39 PM
bigguy75inches's Avatar
Default Rings are blown, 6.0 time need help
alright guys,, my rings are shot on several cylinders, i possibly got a 6.0 to put in, however, the wrecking yard doesnt know how many miles are on the engine cuz the dash was burnt. i need your advice on what all i need to do to the 6.0 before i can install it. txs
Old Apr 25, 2004 | 07:07 PM
Clean it up,install whatever cam you want while everything is accessable and slap badboy in.
Old Apr 25, 2004 | 07:10 PM
since i dont dont know how many miles the thang has,, should i pull the heads or the pan,, or just stuff her in?
Old Apr 25, 2004 | 07:15 PM
I'd try to find the previous owner the wrecking yard should know who they bought the truck from and a phone call might answer a lot of questions.The insurance company would probably know the approximate milage.
Hit Man X's Avatar
I'd pull the heads regardless. I'd toss in some head studs and new head gaskets. Flip it and toss in some ARP rod bolts.
Clean it up like Whitt said and I'd cam it also.
Where in Texas are ya? I can help ya if you need some....
Old Apr 25, 2004 | 07:17 PM
i got less than a grand to work with. end of story
Old Apr 25, 2004 | 07:20 PM
Flyer's Avatar
He's about 40 minutes NW of me.
I like the ideas here .. cam it, pull the pan and put some rob bolts in it. That would give you a good chance to look and see how much slack the timing chain has in it and how worn the bearing/rod journals are.
Hit Man X's Avatar
Hrm... well I'm sure someone would damn near give you a 4.8 or 5.3 for free...well like $300-500 I'd assume. I'd run that for a while until you could do a 6.0 with better bits. No sense in doing something halfassed you will regret later on.
Old Apr 25, 2004 | 07:21 PM
I know that you have a limited budget,but do things right the first time trying to save money by cutting corners will only cost you more money and down time.I speak from experience.
Old Apr 25, 2004 | 07:28 PM
Hit Man X's Avatar
Ah so he's by "The Armpit" too? I suppose that's up between Dallas and Texarkana on 30? It takes me about 3hrs to get to Texarkana from herre on my way to Hot Springs.
If ya need some help... just ask I could make a trip there.
