Ring seating in engine
Old Jan 23, 2010 | 10:29 PM
88bluchevy's Avatar
Default Ring seating in engine
How long does it take for rings to seat in properly. Engine has about 2000 miles on it and has used 2 -2.5 quarts of oil. Been running rotella oil to break it in.
Old Jan 24, 2010 | 08:34 AM
NoShow's Avatar
Depends on the rings, but even with moly rings I would sure think they are seated by now.
Old Jan 24, 2010 | 08:39 AM
cams 98 silverado's Avatar
just saying. im not that good on engine stuff yet. but my buddy had his motor built. and he asked the same thing. turns out the valve seats were leaking and he was eating a quart of oil a week. maybe something to look into? just putting my two pennies out.
Old Jan 24, 2010 | 09:09 AM
hirdlej's Avatar
Shouldn't take that long. If you're sucking that much oil up it's time for a leak down test. Who built the motor?
Old Jan 24, 2010 | 12:08 PM
SILVERADO11's Avatar
That dosent sound good
Old Jan 24, 2010 | 02:15 PM
NoShow's Avatar
There's an easy way to check this. If you pull the plugs and go into each hole with a pipe cleaner or something you should have oil showing up on it. Hey, it's not all that often a motor gets finished and works perfectly for the next 200k miles. Unless you paid a shop to do it.
Old Jan 24, 2010 | 03:01 PM
quicksilverado's Avatar
Mine had about 8k miles on it and was still consuming oil. After a few hard runs at the track they were seated and I had no more trouble.
Old Jan 24, 2010 | 07:54 PM
Coban's Avatar
I'm a firm believer in running the **** out of an engine to seat the rings. You want high load and high cylinder pressure as that is what actually presses the rings against the cylinder walls. The spring tension does nothing in comparison....
Press the gas, don't be scared.
Old Jan 25, 2010 | 08:36 AM
Originally Posted by coban
i'm a firm believer in running the **** out of an engine to seat the rings. You want high load and high cylinder pressure as that is what actually presses the rings against the cylinder walls. The spring tension does nothing in comparison....
x2!!!
Old Jan 25, 2010 | 12:44 PM
real96SS's Avatar
rings typically seat within the first 15 mins of running an engine. if not, than it wasn't properly built to begin with. the best way to insure your rings seat all the way is to break it in with lots of boost! at least that's how we do supras.
5.3Okasai
Mar 9, 2022 01:07 PM
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
Shtbox
Aug 2, 2015 10:52 PM
85SS/85GN
Jul 22, 2015 12:48 PM
