Riddle me this...riddle me that...WHAT THE HELL IS TAPPING IN MY VALVETRAIN??
Old Dec 2, 2005 | 03:22 PM
  #21
ThunderZ28's Avatar
12 Second Club
change out the cam you should change out the lifters..
you can put new lifters on an old cam, but not a new cam on old lifters..
they will collapse expecially if it has a violent ramp rate....
swap out the lifters, and it will fix your problem..
I had the same exact thing happen to mine..
loud tapping coming from the drivers side..
would gradually get worse, and then when I dropped into a lower gear it would get oil in to the lifter, and go away, but it was everyonce and a while at first. then it got so bad it did anytime I got in it...
finally swapped the lifters, and havnt heard it since..
Old Dec 2, 2005 | 03:28 PM
  #22
thunder550's Avatar
High on diesel fumes
ok cool i will do that with the new motor then.
Old Dec 2, 2005 | 03:30 PM
  #23
budhayes3's Avatar
PT's Slowest Truck
Are the Comp OE replacement lifters any good? I usually see them for under $200. Melling also makes lifters for the GenIII...between $160-$170 from what I've seen. Pretty sure that you'd need a second mortgage for factory ones
Old Dec 2, 2005 | 04:48 PM
  #24
ThunderZ28's Avatar
12 Second Club
I just put a set of the comp lifters in mine..
so far no problems...
Old Dec 2, 2005 | 05:19 PM
  #25
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Comp Performance replacements here had the good ole lifter tick in my lil engine. COmp makes two different ones the factory replacements and the "preformance" ones they are like 15 bucks more. Dont ask me the difference cause I dont know.
Old Dec 8, 2005 | 10:57 AM
  #26
fossil's Avatar
11 Second Club
Are you tightening the rocker arm bolts in there sequence at TDC of the compression stroke? For example rotate the crankshaft untill number one piston is at top dead center of the compression stroke. In this position, cylinder number one rocker arms will bo off lobe lift, and crankshaft sprocket
will be at the 1:30 Position. Tighten 1,2,7 and 8 exhaust valve rocker arm bolts to 22 lb ft. Tighten 1,3,4, and 5 intake valve rocker arm bolts to 22 lb ft.
Rotate the crankshaft 360 degress. Tighten cylinders 3,4,5 and 6 exhaust valve rocker arm bolts to 22 lb ft. tighten cylinders 2,6,7 and 8 intake valve rocker arm bolts to 22 lb ft.
Ive seen rocker arm bolts back out, if not done in the proper sequence.
Doug
Old Dec 8, 2005 | 11:34 AM
  #27
O3GMC's Avatar
12 Second Club
Doug
The Crane/VHP rockers have their own (lengthy) method of installation and use studs instead of bolts. http://www.vincihighperformance.com/...TRUCTIONS.HTML
JordanH
Oct 3, 2015 03:59 PM
lxcoupe
Sep 25, 2015 12:36 PM
ZxHybrid
Sep 18, 2015 04:44 PM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
