reverse splits
Old Jun 23, 2004 | 06:31 PM
Sport Side's Avatar
Default reverse splits
How come us truck guys dont run reverse split cams?
with a decent set of long tube headers, no cats, and say a cut out, you will have an awesome flowing exhaust. We're still weak on the intake side though despite head flow numbers are larger on the intake (correct?). With the peoples choice award for a cam, the 212/218, your leaving the exhaust valves open longer when we should be leaving the intake valve open longer. It makes since to increase the intake side of the cam to keep the intake/exhaust flows balanced.
What i'm gettin at is that we should be running higher intake duration numbers rather than higher exhaust duration like comps 212/218. Of course this only applies if you are running a free flowing exhaust. If you have a power adder, a restrictive exhaust, or an ls6 intake manifold a regular split should be fine. am i wrong?
I've been reading all of the cam shaft discussions....if you can't tell
Old Jun 23, 2004 | 08:52 PM
BigTex's Avatar
I think I'm going to test out a reverse sometime soon. I'll also be trying to get proper valve events.
Old Jun 23, 2004 | 08:53 PM
BigTex's Avatar
Knowledge is power....literally in this case.
Blwn99x
Mar 24, 2023 11:14 AM
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
alex226
Oct 14, 2015 07:23 AM
GM1697
Sep 9, 2015 10:31 PM
