returnless fuel system options
Old May 6, 2015 | 07:34 PM
  #21
03sierraslt's Avatar
How much boost do you plan to run? I have converted to a return system.
Old May 6, 2015 | 08:29 PM
  #22
Atomic's Avatar
I have a gauge for that
Originally Posted by bravocompany
hi there im new here I have a question for you guys I just installed 2 walbro pumps 400 lph like 2 weeks ago and this is my 4th time removing the bed of my truck for fuel issues, they turn on but they are not strong anymore they just push a little of gas they are not pushing hard like the day I Installed them ,do I need any kind of harness or different fuel pump set up since I have a returnless system, I have 2008 sierra single cab 4.8 the reason im doing this is cuz im going boost and this thing is killing me I will appreciate any tips thanks!!
Have you had a pressure guage on it to see what its actually doing?
Old May 6, 2015 | 08:34 PM
  #23
bravocompany's Avatar
Registered User
well around 12 pounds I've heard that if you have a return less system you can just drop a 400 lph fuel pump
Old May 6, 2015 | 08:45 PM
  #24
Registered User
I bought one tho it's under way but yesterday i was testing it I removed the supplier line and it barely show some fuel I mean just threw a few drops I know the have power/ground and stuff I putted a empty bottle in the line tip and i found out that it was no pressure.
Old May 6, 2015 | 08:47 PM
  #25
I am not sure if a factory regulator can handle that or not. I have aftermarket every thing.
Old May 9, 2016 | 09:04 PM
  #26
04TurboSilveradoSS's Avatar
Default Adding regulator and return off returnless rails
I'm having a similar issue ... my 04 silverado ss .. nnbs intake and returnless rails on tops of my tsp built 408 ... everything is built for boost and after a year of playing on motor finally putting boost to it ... want to be around 15psi ... my question is how did u do ur return .. I've already gotten a spare bucket assembly and installed my walbro 450 ... I really need a parts list for doing all 8an lines and fitting from pump to rails then rails back the a boost referenced reg. Then back to the tank using the old feed line out as my new return in
Old May 9, 2016 | 09:09 PM
  #27
Atomic's Avatar
Sounds like you already know what you need, just need to shop around on summit.
Old May 9, 2016 | 09:23 PM
  #28
Was just seeing if anyone has a parts list or a order slip to speed up the process ... wife's on my *** for tearing apart my running truck to do yet more mods lol ... don't really get enough time to sit back and hunt with work and kid and p***ed off wife .. u know.. all that plus pulling the engine to freshen it up before turbo gets here
Old May 10, 2016 | 08:37 AM
  #29
I can see if I can find a list, every setup is gonna be different depending on how you do it so it's only a quideline if you will.
Old May 11, 2016 | 09:22 PM
  #30
Justhereforinfo's Avatar
Shoot an email to Racetronix. They're pretty knowledgeable. They knew what fittings and hose type I would need for the corvette filter setup. Even offered to assemble and pressure test it before they ship it out. I think theyre in canada, so shipping was a short wait.
RONIN LSX
Aug 10, 2015 04:45 PM
TAPyvehc93
Aug 8, 2015 06:35 PM
MS3Z
Jul 30, 2015 06:17 PM
4B11T
Jul 13, 2015 03:48 PM
