Return To Returnless fuel sys.
Old Nov 12, 2008 | 06:30 PM
03sierraslt's Avatar
Default Return To Returnless fuel sys.
Who all has coverted from returnless fuel system to a return system? I am thinking about doing it. Trying to figure out what Ill need. If I get a set of 03 fuel rails and a return line what will that leave? What will I have to do as far as fuel pumps go? Got a 255lph intank now.
Old Nov 12, 2008 | 06:41 PM
GMCtrk's Avatar
what are the advantages of a return fuel system?
Old Nov 12, 2008 | 06:51 PM
Mangled03gmc's Avatar
Baltimore Whore
I know now it moves the FP reg to the rail, instead of the tank..
John
Old Nov 12, 2008 | 07:38 PM
Lower idle pressure ( Easier to control big injectors) Higher pressure when under boost ( More fuel out of same injectors)
Old Nov 13, 2008 | 09:51 AM
Anyone?
Old Nov 14, 2008 | 09:36 AM
OnyxSilveradoSS's Avatar
I went the other way...and have the rails w/reg if you want them.
I think thats it, the rails, w reg, the return line to the tank. PCM needs different values in some table bc the pressure changes, where with out the return its constant.
Old Nov 14, 2008 | 11:32 AM
I will be in touch via PM this eve.
Old Nov 14, 2008 | 08:12 PM
The tuning changes are no big deal, I can take care of that easily. Just got to figure out how I want to do the fuel setup. I am thinking that I should run dual intanks.
Old Feb 12, 2009 | 05:21 PM
TURBHOE's Avatar
isn't there a right up about this some where. i want more info on the return portion as far as geting it back inside the tank, and makeing the venturi setup still work correctly to keep the bucket filled.
Sevex
Aug 22, 2015 12:12 AM
TAPyvehc93
Aug 8, 2015 06:35 PM
MS3Z
Jul 30, 2015 06:17 PM
GMCtrk
Jul 17, 2015 06:39 PM
