Restrictive exhaust holding the 6.0L back?
Old Oct 15, 2005 | 08:21 PM
Black02Z71's Avatar
Default Restrictive exhaust holding the 6.0L back?
I know my exhaust is too small right now, I'm just wondering how much I will gain by uncorking it a little.
The exhaust is stock up to the 3" in dual 2.5" out magnaflow muffler, then it reduces down to 2.25" tail pipes. When I had the exhaust made up, the truck was 100% bone stock, so 2.25" tails were adequate, but now I think the 6.0L needs more breathing room. Up-front that flattened 2.5" crossover pipe can't be helping any ether.
For now I was thinking of ditching those tiny crimped up tail pipes, and running dual 2.5" pipes out the pass side, just before the tire, I would just dump it, but I think it would resonate too much. If I keep the truck as it is or go the h/c route I will get 2.5" true duals, but I've been thinking about building a custom rear mount turbo system.
Old Oct 15, 2005 | 08:36 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Just an FYI I have a true dual setup and will be installing the 408 in about a month an I am going to back to a y-pipe setup and it should flow more than enough. Im going to use a pacestter 3inch ory to a corsa catback.I would put a cutout at teh y-pipe. You would be surprised how much hp a y-pipe setup can handle there are tons of fbody guys that use the y-pipe and have over 500rwhp.
Old Oct 16, 2005 | 07:12 AM
cbanchin's Avatar
I ran a magnaflow X factor 3 in and 3 out and the truck runs great now. It had a bit of reson noise to it new. Now that it has about 3000 miles on it u don't notice it. The muffler has a x flow in it so u don't need the x pipe. It has really livened up this 6.0. By the way true duels out back 3 all the way.
Oobray
Jun 13, 2022 03:38 AM
ARC
57
Feb 21, 2022 10:54 AM
Suburban2500
Jul 19, 2015 04:50 PM
06 4.8
Jul 14, 2015 08:09 AM
NuckenFuts
Jul 9, 2015 08:45 AM
