Engine break in??
Engine break in??
how conserned should i be about breaking in the motor before i start changing things on it and adding more power, will it affect my coputer or hurt mileage??
Why did you ask a loaded question???? There will be just as many answers on both sides of the fence for this one...
Go to a race shop and ask them.
Just do it, run it that is why you bought it!!!!!
Running a new engine hard is necessary for the rings to have the required high cylinder pressure to seal properly under load. I worked for a NASCAR race team and watch plenty of motor broke in on the dyno. They firsts started them, braking in the cam, and shut them down, checked for leaks and retorqued a few things. The next start, they made full pulls with them till the torque numbers stopped climbing and then they knew the rings where seated and the motor was ready to go racing. HTH
Baltimore Whore
Just think when you get a crate motor with the dyno sheets they run the **** out of it and it is fresh. we put a big cam in my dads 427 drag boat and had to run it a 5000 rpm for a period of time to get the cam and things seated right.
SLOPONY
20
10-18-2016 06:05 AM
5.3lSilverado
25
08-29-2016 12:48 AM
