Replaced lifters and still ticking
Old Aug 28, 2016 | 08:53 PM
Wolftrk99's Avatar
Pushrod checker... You may need longer pushrods.... Sounds like your preload is a little light... Due to the cam....
Old Aug 28, 2016 | 10:26 PM
mhorn0817's Avatar
How do I properly set preload? Seems like it's louder on the passenger side then the driver side
Old Aug 28, 2016 | 10:51 PM
Wolftrk99's Avatar
With the proper length pushrods.... Thereis a thread that goes in depth on it somewhere on here... But the stock pushrods, iirc, give you right at the minimum preload, and if the base circle of the cam is smaller than stock you need longer rods... Im sure someone will chime in with the proper spec off the top of their head, but i wanna say you want something like .060-.080 preload to quiet down the valve train, if youre running stock pushrods which are something like 7.395 you probably need to step up to a 7.425 or maybe even a 7.450... Again these are just off top of my head, and i may be wrong, but pushrods length checking tool is like $20...and a lot cheaper than buying two or three sets of pushrods to try and see...
Old Aug 31, 2016 | 07:40 PM
mhorn0817's Avatar
One thing that makes me think it's lifters or possibly something else is that the noise is mainly on the passenger side, noise was on passenger side before and it's still there on passenger side. Possible rockers?
Old Aug 31, 2016 | 08:31 PM
Wolftrk99's Avatar
Can you isolate which cylinder it is?
Old Sep 10, 2016 | 10:16 PM
dry_kill's Avatar
Oil pump possibly? Had a buddys who's lifters got noisey but oil pressure was a little low. Put in new oil pump and that fixed it
Old Sep 11, 2016 | 01:29 PM
mhorn0817's Avatar
Havnt natrowed down which cylibder or where noise is
Oil pressure is good. 70 at startup, 44 at idle, 60 while crusing
jzobie
Mar 10, 2017 08:47 AM
Dan Neumann
11
Aug 20, 2016 09:56 AM
EmmerichLSx
Aug 9, 2016 11:45 PM
01SilveradoJakee
Aug 7, 2016 06:13 PM
fctry286
Aug 7, 2016 12:18 PM
