Replaced lifters and still ticking
Old Aug 28, 2016 | 09:57 AM
mhorn0817's Avatar
Default Replaced lifters and still ticking
I replaced the lifters in my wifes Denali, and the tick is still there. I used new ls7 lifters, had them soak in oil overnight, followed directions to a tee... Could I have gotten a bad lifter or some other problem?
Old Aug 28, 2016 | 10:14 AM
Mean Green z28's Avatar
11 Second Club
What kinda preload you running?
Old Aug 28, 2016 | 10:55 AM
mhorn0817's Avatar
Ummmmmm.. I tightened rockers down 9 then 18 then 22 ft lbs. Spun motor over ny hand and rechecked and all were good at 22ft lbs
Old Aug 28, 2016 | 11:36 AM
Wolftrk99's Avatar
How were the bearings in the rockers? How did the old lifter rollers look... Is it a tick or an exhaust leak? Do you have a mechanics stethoscope?
Old Aug 28, 2016 | 02:14 PM
mhorn0817's Avatar
Didn't really inspect the rockers but they all had the same amount of movement.
Some of old lifters had slight cupping where the tick was.
Sounds like a tick and not a leak, gets a little quieter when warmed up. Don't see or feel any leaks.
No i do not have a scope
Old Aug 28, 2016 | 03:00 PM
EmmerichLSx's Avatar
formerly Emmerich 5.3 (2013-11-30)
A small exhaust leak out the manifolds can sound like a tick.
Old Aug 28, 2016 | 03:26 PM
Wolftrk99's Avatar
I have an exhaust leak when its cold that sounds like a lifter, but once it warms up it goes away, its at the y-pipe seal... Truck has had it, i will fix it and it comes right back.... Hell ive even replaced the exhaust and still had it... Engine mounts are the next victim, along with a set of longtubes.... Going to eliminate the issue all together and be done with it...
Old Aug 28, 2016 | 03:32 PM
mhorn0817's Avatar
ive checked the manifolds and theyre good, new oem gaskets. dont feel or see or hear anything coming from them or any part of exhasut
Old Aug 28, 2016 | 05:29 PM
Wolftrk99's Avatar
Its possible you may have a bad lifter, a weakspring, or a bad lobe on the cam, is it the factory cam?
Old Aug 28, 2016 | 07:46 PM
mhorn0817's Avatar
Small cam and pac 1218 springs.
