Replace A/C Belt?
Old Sep 24, 2003 | 11:41 AM
SmokinLM7's Avatar
Default Replace A/C Belt?
I know this is a stupid question, but I must know it before I install the ASP pullies.... Should the A/C belt be replaced with another size belt or will the original work fine? Anyone know which are the belts that should be used for the crank and alt. pulley set?
Old Sep 24, 2003 | 11:56 AM
1BADHD's Avatar
Default Re: Replace A/C Belt?
Yes, it need replaced. Dont know off hand what the belt number is for the set.
Old Sep 24, 2003 | 12:21 PM
CashDudeHomie's Avatar
I think the hardest part of my ASP install was getting the new AC belt on. Good luck!
Old Sep 24, 2003 | 02:36 PM
JSmith's Avatar
When you do put the ASP's on check your A/C belt tensioner. Mine has very little tension and barely holds the belt tight.
Old Sep 24, 2003 | 02:52 PM
FILE's Avatar
SmokigLM7, Who's is putting it on for you?
Old Sep 25, 2003 | 12:21 PM
SmokinLM7's Avatar
Thanks for the feedback guys. So I have to buy the AC belt too... I still dont know someone that can install the pulleys for me. I can't do it myself since I dont have the tools. Hey Shark_g, do you know who might be able to install them for me? Also, did you have to replace both belts (A/C and Crank) when you installed them? Thanks again.
Old Sep 25, 2003 | 12:48 PM
BigKID's Avatar
Accessory Belt w/ Crank only: Gates K060895
w/ Crank & Alternator Pulley: Gates K060900
w/over-drive Alt. pulley: Gates K060882
AC Belt: K040345
Yes you have to replace the AC belt.
Old Sep 25, 2003 | 02:32 PM
FILE's Avatar
My friend and his cousin put it on for me. He posts here too. His handle is davidmtz. E-mail him and let him. know.
Old Sep 26, 2003 | 12:46 AM
SmokinLM7's Avatar
Thanks for the info BigKID, I bought the pulley set that comes with the little alt. pulley so correct me if I'm wrong: I need the Gates K060882 and the AC Belt: K040345. Shark_g, I think I'll send your friend a mail see if we can arrange something.
Old Sep 26, 2003 | 09:54 AM
BigKID's Avatar
Ding, Ding, Ding... We have a winner!
BTW.. you cant install it without and impact but it just takes patients. I did mine without one. Although an impact really makes it easy. Other than that the only other tool you need is a pully puller, which you should be able to rent from you local autoparts store.
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Mr. Chainsaw
Sep 24, 2015 09:45 PM
97aztecgt
Sep 10, 2015 05:07 PM
Hpinnovate
Sep 4, 2015 02:28 AM
hackrst
Sep 2, 2015 05:27 PM
