Removing Stock Y-Pipe
Old May 1, 2007 | 10:55 PM
xsports33's Avatar
Default Removing Stock Y-Pipe
Did you guys have to drop the transmission x-member or did you just wrestle the Y-pipe out? This in on a 4x4. I tried for about an hour to wrestle the y-pipe out and i couldn't get it out, then it got too dark to see anything so i'm leaving it until tomorrow.
If you did drop the crossmember, did you have to support the trans with a jack first? Thanks guys
Old May 1, 2007 | 10:58 PM
RoosterMcCandles's Avatar
I couldn't wrestle mine out either. A sawzall took care of it very quickly. You can drop the crossmember if you want but it would be wise to support the tranny...
Old May 1, 2007 | 11:04 PM
xsports33's Avatar
Cool... thanks bro. As much as i'd love to cut it out, i have to save it to pass emissions laws in CA.
Old May 1, 2007 | 11:48 PM
Kingpimp's Avatar
I didn't have to drop mine. 99 RCSB 4x4. I did have the push the cat-back portion of the exhaust towards the back of the truck to get more room.
You should be able to wrestle it out.
Old May 1, 2007 | 11:49 PM
BLACK04VHO's Avatar
I wrestled mine out. Unbolted the y fromthe exhaust and the manifold bolts and it was a bitch but I got it out with out cutting. This was on a reg. cab 4wd.
Old May 2, 2007 | 08:04 AM
Moddoo's Avatar
This trick will make it easier to move around under there.
kr1s
Aug 24, 2015 05:34 PM
lxcoupe
Aug 15, 2015 06:13 PM
08nali
Jul 23, 2015 11:39 PM
Chiphead
Jul 13, 2015 10:16 PM
