Removed headlight w/ K&N FIPK, does it work?
Old Jun 24, 2003 | 10:17 PM
14 Second Truck Club
Default Removed headlight w/ K&N FIPK, does it work?
I read about it in a magazine awile back. I'm thinking about trying it later in the year at the track. It seems like it would work in cool weather. Has anyone tested it at the track or anything?
Old Jun 24, 2003 | 10:32 PM
BigJ's Avatar
Default Re: Removed headlight w/ K&N FIPK, does it work?
I removed my headlight the last trip to the track. My times were way off (bad wheel spin) so my actual track times are not worth posting, but forced air right into the filter can not be bad. Also lower the tailgate (keeps the weight in the rear for traction, but helps with wind resistance), keep your spare tire on, and fold in the side mirrors. All that, and lowering the tire pressure in the rear tires, should make for a good run.
Good Luck
Old Jun 25, 2003 | 02:42 AM
LS1TECH Sponsor
I don't know about 02 and previous truck body style with the 03 the headlights are quick relese, just a pin. Will try removing the right headlight and tailgate next time at the track.
Old Jun 25, 2003 | 07:16 AM
Scream's Avatar
MOOBIES Moderator
I always remove the passenger side headlight when I'm at the track, and have found it to be worth about .1-.15.
Old Jun 25, 2003 | 08:33 AM
creederado's Avatar
while your at removing the headlight at the track, ther's a rubber flap you can remove by the radiator and a plastic brace your can cut out with a dremel. Just make sure you don't weaken the headlight bracket. For the 2 seconds it takes it is easy at the track.
pics below;
http://photos.yahoo.com/bc/creederad...tos.yahoo.com/
Old Jun 25, 2003 | 10:44 AM
BigJ's Avatar
creederado, where did you get the open end filter? What size is it, and how much was it? Thats the filter I have been looking for.
Thanks.
Old Jun 25, 2003 | 10:54 AM
BigKID's Avatar
I have also noticed about a tenth and half a mph but removing the light. I do it every time I go. BTW.. you can see it in the vids I posted in the lounge.
Old Jun 25, 2003 | 03:45 PM
creederado's Avatar
http://www.autocandy.com/powerstack.htm
I have a longer filter for sale if your interested. Send me a pm. The filter I used is the same size as the KN. I bought a cleaning kit but I'm pretty sure it is the same ingredients as the KN cleaning kit but I'll have to check.
Old Jun 25, 2003 | 06:11 PM
creederado, where did you get that clear plastic thing over your filter? Please let me know! PM me or something!
Old Jun 25, 2003 | 07:18 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Yea, did you just buy some fiberglass or something and fab that up?
