Reliable 102mm DBW throttle body?
Old 09-15-2010, 03:00 PM
Iraq Sucks's Avatar
Default Reliable 102mm DBW throttle body?
Looking for a 102mm TB to match up with my FAST 102 intake. I have heard nothing but negative things from people that have installed aftermarket DBW throttle bodies. Anyone have input on if I should stick w/ a ported TB off a vette or spend the ridiculous coin(a Nick Williams 102mm DBW= $575!!!) on a 102mm? If so, which brand? Nick Williams is the only 102mm DBW I have found.
Old 09-17-2010, 08:09 AM
moes04silverado's Avatar
as far as i know thats the only one that i have found! i've had conversations with people at FAST about making a DBW 102mm, didnt get a good feeling that they wanted to go that route. But i guess i feel if all the newer cars (2010 camaro?) have DBW, then why not? But 575 bucks is all that bad... BBM from summit for 90mm is $350+/-
Old 09-18-2010, 10:32 AM
Iraq Sucks's Avatar
I'm coming to the conclusion that the knowledge in the aftermarket just is not where it needs to be in order to produce these things reliably yet, I guess I'll wait 'em out.
Old 02-12-2012, 08:07 PM
Truckzilla's Avatar
Unhappy
It seems like someone coming out with an intake manifold for a five barrel carb before the carb is available. Go Figure.
Old 02-12-2012, 08:39 PM
BrutalSierra's Avatar
FS: 105mm TB
Old 02-12-2012, 08:48 PM
1Bear's Avatar
Possibly look into the 102mm TPIS unit like supersub is running. From all accounts he feels these are the best large bore electronic throttle bodies on the market and I wouldn't take his recommendation lightly.
Old 02-12-2012, 08:58 PM
evand's Avatar
I just picked up a 90mm for 160 off ebay and an adapter to smooth the flow into the fast.
Uploaded with ImageShack.us
unless your going for crazy goals. I would rather save a few $$
Old 08-27-2013, 09:40 PM
Registered User
MikeF1185's Avatar
Did this 90mm work for you? What's it off of? Is the connector 6 or 8 pin for the new one and your stock? I'm running into DBW throttle body issues in my 04 denali.
lucas287
31
01-12-2021 06:18 AM
blownss27
08-14-2020 08:27 AM
pewter00
12-13-2015 10:38 PM
gaps
10-15-2015 02:53 PM
Cowboy Tom
09-05-2015 04:29 PM
Quick Reply: Reliable 102mm DBW throttle body?
