Reduced engine power
Old May 2, 2006 | 11:24 AM
  #31
Whippled 496's Avatar
Just wanted to say thanks to everyone who helped me out here, i forgot to do that..
Old May 2, 2006 | 01:09 PM
  #32
custom 68's Avatar
Linda, I just saw this but I would still check your grounds, it initially (as I read through this) sounded like a ground problem but sounds like the PCM...
Good luck
Dave
Old May 2, 2006 | 02:06 PM
  #33
FlaBouy's Avatar
Originally Posted by GMC_DUDE
Linda,
As an electrical engineer who works with engine controllers for a living (albeit diesel instead of gas) I can tell you with 100% confidence that the smaller pulley had NOTHING to do with the pcm getting fried. It was merely a coincidence that the two happened together. Most likely there was either a manufacturing defect (I've seen it happen) or Westers touched one of the pins without grounding himself first, which caused a static spark and ESD damage, which typically shows up about 3-6 months later. Continue to enjoy your new pulley, get a tune, and make Westers give you a new pcm.
Sorry just saw this thread. Been busy for a few days. I do my own tuning with HP Tuners and your PCM issue has no correlation to the pulley install. I have done 3 on my truck. The Reduced Engine Power Mode also is a safety that GM programs in the truck to prevent the user from driving the truck when a critical parameter is out of tolerance. There are a multitude of issues that will throw the truck into this mode and most if not all thow a DTC.
Had I caught this earlier I would have suggested the PCM because I know that the recent addition of a blower or smaller pulley always results in a new tune. Most people will recieve a new (Used) PCM through mail order from a tuner. Most guys recycle PCM's so that would have been the most logical place to start. When changing out a PCM it is imperative that the battery be disconnected or the electronics in the PCM are subjected to stray voltage/cross voltage/insufficient grounds for a brief period.
With all this said, I am glad you got it figured out Linda. I too have had issues with my PCM, mostly due to low battery voltage while I am reflashing.
Good Luck.....
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
steves86ta
Jul 28, 2015 10:21 AM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
