Redline Water-Wetter
Im running water wetter in my coolant...and it dropped the temp to about 205 or so all the time it never moves when its running at op. temps...what t-stat should i go with if i dont have a tune, but e-fans?
What thermostat will depend on what you plan on doing. I put a 160 in mine because I am FI but if I wasnt I would have left it stock I believe. However mine ran at 191-194 stock not 205 so.... The 160 in mine nets mid 170's on the highway and low 180s in traffic. I dont have my fans turn on until 185. In traffic with the AC on it will run at 181 ( Fans on High)
Fron http://www.redlineoil.com/tech_faq.asp
Is WaterWetter compatible with antifreeze?
WaterWetter is compatible with all antifreezes including the new extended-life types that are œ factory-fill in your new road car. Simply pour it in.
