Recommend Me a Oil Pump L92
Old Mar 13, 2014 | 06:04 PM
jgreen-fsi's Avatar
Default Recommend Me a Oil Pump L92
I need some help from the brain trust. I am about to drop a cam in my 6.2 L92. With almost 100K, I thought it might be a good idea to swap the timing chain and oil pump. What does everybody recommend for a oil pump? Should I just go back with a L92? Or is there a better LS style pump?
If it matters, I will be deleting the VVT (no AFM or DOD). Also I will replace the o-ring.
Thanks in advance!
Old Mar 13, 2014 | 06:10 PM
oakley6575's Avatar
The OEM pump is fine. The L76 pump is a stock high pressure pump if you want to go that route. I run a high volume/pressure pump in my 4.8L from melling that I like a lot.
Old Mar 14, 2014 | 11:00 AM
Robert91RS's Avatar
L92 already uses a high volume pump, stick with oem.
Old Mar 14, 2014 | 12:53 PM
smokeshow's Avatar
Mod with training wheels
That L76 bastard is known to take a **** though. The plunger in the pressure relief gets jammed up and you lose oil pressure when RPMs come down lol. Not sure if the factory just didn't do a good job deburring the plunger bore or what...
Old Mar 14, 2014 | 01:14 PM
oakley6575's Avatar
I didn't know that. I was going to run one until I found my melling sitting on the shelf. Good think I didn't
Old Mar 14, 2014 | 02:50 PM
jgreen-fsi's Avatar
Thank y'all for the input. I'll just replace it with OEM.
Old Mar 19, 2014 | 02:37 PM
06bluchevy's Avatar
I would remove the relief valve that is built in the back of the pan tho if you have one.
Old Aug 11, 2017 | 04:19 PM
JASON 77's Avatar
Default Pump
sorry to bring an old post back. But why to remove the relief in pan?
Old Aug 18, 2017 | 04:17 PM
RPMSpeed Tech's Avatar
Truck Sponsor
There are 2 reasons
1. it still will bypass or bleed off oil pressure from 55 to 60 psi which isnt always good
2. it can cause othe oiling issues as the oil shoots out of the side of the bypass. GM has a tsb out about it where they update it with a splash shield/collar.
5.3Okasai
Mar 9, 2022 01:07 PM
03chevytruck
Nov 7, 2016 04:43 PM
JordanH
Aug 8, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
