reasons for misfire on vortec 350
Old Mar 14, 2006 | 08:38 AM
orangebowtie's Avatar
Default reasons for misfire on vortec 350
I posted a thread recently about a cylinder 3 misfire.. the code will not go away and im not sure why its on.. it seems to have decent power.. it just seems to shift funny at times and doesnt have bottom end.. i am also having problems with starting.. i was told that could be the fuel pressure regulator.. im gonna replace an injector and the fuel pressure regulator.. im looking for advice.. what else could be wrong with it?/
Thanks BRIAN
Old Mar 14, 2006 | 09:07 AM
James B.'s Avatar
I wouldn't think it's the FPR. When those let go they leak internally (it is INSIDE the manifold) and they flood out cylinder 6 and 8 usually. It can be a clogged poppet. It can also be a bad distributor cap. The "crab cap" the Vortecs use has conductors that cross over inside of it, and that makes them prone to break down with carbon arching. On your cap look at where the #3 spark comes from to get to the driver side and ou'll see what I'm talking about.
If you do need to replace the FPR or a poppet, buy the whole retrofit Multec-II assembly. It doesn't have poppets and is superior to the old design because of it.
Old Mar 14, 2006 | 12:59 PM
If it's always on cyl#3 you might check your injector on that cyl.
If it was a random engine cyl misfire I would say it could be several diffrent things.....but the fact that it's on #3 all the time.....make sme think injector.
Old Mar 14, 2006 | 02:15 PM
i replaced the cap and rotor and it didnt make a difference.. im gonna change the fuel pressure regulator and check the injectors.. im not sure what else to do..
Old Mar 14, 2006 | 02:38 PM
Trotorx2's Avatar
I had the same code once on an '82 and it was the #3 injector. It just stopped working one day. I tried replacing the cap, rotor, plugs and wires and no change. Changed the injector and it ran fine.
The truck ran ok at speed but was weak accelerating and took a couple hundred more RPM to cruise at 70. Gas milage sucked too.
Old Mar 14, 2006 | 04:35 PM
thanks for the help.. So do you think the injector is bad.. i was gonna replace it anyway.. im glad that i found someone that has had similar problems as i did.. im gonna check the injector then.. it must be clogged or something .. thanks for the help
BRIAN
Old Mar 15, 2006 | 09:28 AM
Trotorx2's Avatar
I couldn't see anything wrong with it but changed the injector anyway and that fixed mine. Hope it does for yours too.
Old Mar 15, 2006 | 11:57 PM
hog's Avatar
hog
BRIAN
The MULTEC 2 upgrade is only like $266 and comes with anew FPR, buying an individual imjector is like $80-$90.
Here is the kit I am talking about(scroll to bottom)
http://www.pacificp.com/forum/viewtopic.php?t=981
Comparison of MUltec 2 and stock popets on top of each other(scroll down)
https://www.performancetrucks.net/fo...d.php?t=356743
For under %300 you get 8 new UPDATED true MPFI injectors with a new FPR. These are much better than the old poppet style injectors.
peace
Hog
Old Mar 16, 2006 | 08:18 AM
I didnt get ur post until today.. Yesterday i changed my fuel pressure regulator and replaced cylinder 3 and 6 injectors. It runs a lot better now.. I got all the power back that i lost. I was just wondering what makes the Multi-tec 2 upgrade so much better than the stock injectors.. the more the info the better..
thanks
BRIAN
Old Mar 16, 2006 | 08:19 AM
also,, i see that many of you put marine intake manifolds on instead. is there a reason for that.. do you get better performance out of them? how much do they cost and what are the benefits and disadvangtages..
thanks
BRIAN
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
hodge9386
Oct 25, 2015 01:26 PM
JordanH
Oct 3, 2015 03:59 PM
Lthompson
Oct 2, 2015 12:45 AM
