REar end problems
Old Aug 6, 2004 | 07:14 AM
RED2K's Avatar
Default REar end problems
There is a rubbing noise when ever i turn a corner. It almost sounds like tires rubbing. It started when I put the boyds on. I did a run out test and the tire are right on. Could my eaton be messed up? Checked backlash and everything on the gears and they show good
Old Aug 6, 2004 | 08:19 AM
zippy's Avatar
it looks like you're running an eaton limited slip and if you're running synthetic fluid in it that can happen. i've ran into that before.
Old Aug 6, 2004 | 01:04 PM
12sec.5.3's Avatar
Make sure your lugs didn't come loose. I know it sounds stupid, but I've seen it happen before.
pjb1972
Sep 17, 2015 02:06 PM
TimDave217
Aug 24, 2015 04:38 PM
vipergtrdj
Aug 6, 2015 10:19 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
