rear end fluid change after Eaton?
Old Aug 17, 2004 | 02:17 PM
O3GMC's Avatar
12 Second Club
Default rear end fluid change after Eaton?
I had an Eaton posi installed a few thousand miles ago, and just realised that I might have needed to change the fluid after 500 miles or so.....or is this only neccessary when changing gears as well? I re-used the factory 3.73's and conventional 10w-30 (I think) and a bottle of friction modifier.
Old Aug 17, 2004 | 02:28 PM
12sec.5.3's Avatar
I don't think you'd have to change it, but it shure wouldn't hurt. I thought you were supposed to use gear oil like ''80w-90''??????
Old Aug 17, 2004 | 02:32 PM
12sec.5.3's Avatar
Have you ever experienced it leaking. I've tried factory gasket, gasket material, and permatex and it still leaks. Maybe mine is bent. Probably gonna get a new cover.
Old Aug 17, 2004 | 03:00 PM
I dont think 10w30 is correct. - might check that one.....
Old Aug 17, 2004 | 05:12 PM
Mn Avalanche's Avatar
the gear oil for factory g80 units are 75-90 full synthetic.with the eaton its 80-90gl5 with limited slip additive.10W30?thats scary
Old Aug 17, 2004 | 05:51 PM
O3GMC's Avatar
12 Second Club
sorry for the confusion, I was kinda heading out the door when I was posting......I meant 80w-90
Old Aug 17, 2004 | 06:06 PM
James B.'s Avatar
Yes, 80/90 Mineral-Based gear oil is correct. 4oz. Limited-Slip additive (friction modifier) is required for the 8.5/8.6 10-bolt.
Absolutely never use synthetic with an Eaton Posi. You have it right.
I changed my fluid after the first 500 miles. It was clean. I also followed the break-in procedure like it meant life or death. The best arguement for opening it after the first 500 is to check contact and look for signs of trouble, before they become expensive.
Old Aug 17, 2004 | 06:18 PM
O3GMC's Avatar
12 Second Club
Thanks for the info James, I wasn't sure if there was any specific break in for just the posi, but I was easy on it for at least 500 miles.
I used the gasket that came with the install kit from Randy's Ring and Pinion...and no leaking as far as I can tell, although I haven't been under there in quite a while.
pjb1972
Sep 17, 2015 02:06 PM
Oobray
Aug 12, 2015 10:56 AM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
Ketis
Jul 23, 2015 12:37 PM
