Rear disc rattle
Old Jun 13, 2004 | 08:19 PM
Question Rear disc rattle
When riding on cement streets when ever I cross the expansoin joints in the street (ABOUT EVERY 20 FEET SPACING ) I hear my disc rattle.I know it is rear disc because applying the brakes ever so slightly rattle stops.Is there an easy fix other than replacing pads.By the way I only have 25000 miles and it's been doing it for a while now.
Old Jun 13, 2004 | 10:48 PM
JSmith's Avatar
It's not your rotor that's rattling because if it was, your tire would soon fall off.
Old Jun 14, 2004 | 02:19 AM
WaitinToDrag's Avatar
i have a very similar rattle in the same situation. i cant tell if mine is in the fron or rear..but i know is the drive side. i cant figure out what it is!?
Old Jun 14, 2004 | 05:56 PM
ttt..
Old Jun 14, 2004 | 08:36 PM
nativetexan's Avatar
13 Second Truck Club
Crawl under there with a rubber hammer and start beating on stuff. Well maybe not too hard. See if you can get it to make the noise and then pin-point it. It shouldn't be a rotor. Maybe a shock or something to easy to find.
Old Jun 14, 2004 | 09:21 PM
I know that the noise is coming from the disc brake pads themselves,never once thought anything as stupid as a loose rotor.I just wanted to know if NBS trucks have any bushings or sleeves that the disc brake pads slide on that could be worn or causing rattle.thanks for the suggestions.
Old Jun 14, 2004 | 11:19 PM
Mod Maniac's Avatar
If you have sliding calipers check the anti-rattle springs. If the anti-rattle spring is missing or has been positioned incorrectly, a rattle will be heard when the brakes are not applied and the truck is traveling on a rough surface. If they are floating calipers, check the pins that hold the caliper to the anchor plate. They might be loose. A rattle can also be caused by excessive clearance between the rotor and the pads.
Old Jun 14, 2004 | 11:24 PM
thanks,that sounds like the info I was looking for.
Old Jun 17, 2004 | 12:21 AM
Mod Maniac's Avatar
How did ya make out stall speed? I forgot to mention that some of the GM truck pads have L-shaped tabs that must be folded in order to keep the pad from rattling. Good luck.
Old Jun 17, 2004 | 07:30 AM
Have not had time to look in to it yet.Let you know ,thanks again.
5.3Okasai
Mar 9, 2022 01:07 PM
Corvette454l88
Sep 1, 2016 01:24 AM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
mrgrim
Jul 8, 2015 08:12 AM
cwylie
Jul 7, 2015 11:42 AM
