Re installing valves
Old Dec 1, 2010 | 03:47 PM
trackaddictedtundra's Avatar
Default Re installing valves
I'm going to do a little cleaning up of a set of 852s heads I've got. Is there any way for me to re-install my own valves? I'm not enlarging them or anything. Just want to be able to put the stock ones back in. Is that an option?
Old Dec 1, 2010 | 03:50 PM
BlackGMC's Avatar
Resident Retard
i am no expert but i think if you do that, keep track of the hole it came out of and put them back in the same hole... Might as well change out the valve seals while your at it...
Old Dec 1, 2010 | 03:51 PM
I'd like to change the seal, but I'm not sure how to do it. So you can just set them back in there as long as you make sure you put them back in the hole they came out of?
Old Dec 1, 2010 | 04:16 PM
00buckshot's Avatar
The exhaust and intake valve stem seaLS ARE DIFFERENT, but they aren't hard to change as a twist of a pair of pliers will pull them right off, a dab of oil and a finger push will install the new ones. now gettin inot the valves, you could mark them and put em all back in the same place, or you could use some good ole valve grinding compound and a cordless drill and lap the valves yourself, but be careful.
Old Dec 1, 2010 | 04:27 PM
Phantom's Avatar
11 Second Club
Stock valve seals may different, I'm pretty sure they're just different colors, but if you order a new set of VITON seals, they're all the same
Old Dec 1, 2010 | 04:28 PM
BlackGMC's Avatar
Resident Retard
so do the valve have to go back in the same exact position they were or does it just need to go back in the same hole? Meaning could you rotate the valve 50* and put in back in and it be OK?
Old Dec 1, 2010 | 04:32 PM
Phantom's Avatar
11 Second Club
I'm no expert, but I imagine the valve would spin with the valve spring so it wouldn't really matter on position??? I can't say for sure though
On the couple sets of heads I've put together, I've just put them back in the same hole and lapped them in.
Old Dec 1, 2010 | 04:43 PM
Thanks for the info. Guess I'll find a place to buy some new seals and go from there.
Old Dec 1, 2010 | 06:07 PM
JS01's Avatar
Just has to go back in the same hole.
I would lap them as recommended previously in this thread.
http://www.cylinderheadsupply.com/kl1242-1.html
The_W
Oct 28, 2015 09:00 PM
DrX
Aug 19, 2015 04:45 PM
jroctpb
Aug 11, 2015 03:52 PM
low2001gmc
Jul 23, 2015 05:10 PM
Mzay
Jul 6, 2015 11:05 PM
