Ramcharger's timing tuner
Old Mar 16, 2004 | 12:57 AM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Default Ramcharger's timing tuner
Anyone use this? Ramcharger Timing Tuner
Going to get a Nelson tune, then a little later start with a NOS 5177 kit.
It says the N20 features are:
-"activation control on RPM" This is a window switch right?
-timing retard (which I need too right? I read about 2 degrees for every 50 shot..is that about right?)
-activation delay (What is this?)
I figured I'd get this instead of buying the MSD window switch since it's got more options
Old Mar 16, 2004 | 12:16 PM
TTT....I guess I'll be the first to use this?
Old Mar 16, 2004 | 12:35 PM
RED2K's Avatar
buy it, try it, own it, install it, use it, report back to us
Old Mar 16, 2004 | 12:51 PM
BlownChevy's Avatar
blownerator
25 Year Member
Looks interesting! What is their return policy?
Old Mar 16, 2004 | 01:24 PM
Will do
Old Mar 17, 2004 | 01:15 AM
GoldenVelvet's Avatar
Ask this in the Nitrous forum. The will have a little more experence with this toy.
Old Mar 17, 2004 | 01:26 AM
Hit Man X's Avatar
Use that piece ese. It will allow you to run full timing N/A and retarded for the bottle. I used a box by MSD years ago called their "Digital Multi Retard" and it does the same thing... when the nitrous solenoids ground and open it grounds a wire and causes the box to pull timing on whatever amount you dictate.
best of both worlds in power...
Old Mar 17, 2004 | 01:42 AM
That is a cool toy!! It also has window switch ability?
Old Mar 17, 2004 | 01:53 AM
Hit Man X's Avatar
I dunno, I've always sprayed with a highstall converter out of the hole and through the shifts.
Stock converters aren't built for nitrous or big power...they are usually cast covers and have no antiballoon plates that prevent swelling under high instant torque increases. Well the stock Lightning converters have balloon plates...
Old Mar 17, 2004 | 02:26 PM
oxidizr's Avatar
Moderator / Sponsor
You dont really need the retard if you are runninig a dry shot. I have used advanced timing and upto 150 HP with no problems. NO crappy fuel though. It seems like a solid piece of electronics but until I see Bigger N2o jetting I wont be playing with retard much.
