Radix Update, Tightened Radix Manifold bolts
Old Feb 1, 2005 | 08:54 PM
moregrip's Avatar
what a rush!
Default Radix Update, Tightened Radix Manifold bolts
well...... after Sunday at the truck meet and the fact that I should have retightened my Radix Intake Manifold Bolts a while ago, currently 750miles on my setup, I re-tightened them tonight. Took about 4 passes to get an even 89inlbs. Good-to-Go.
As for Power, my 32" tall 10+" wide tires are no match for the Radix's Torque output on my 6.0/4L80E Combo. I told the wife that I think this first set of Rear Tires will go fast, she said, "Enjoy Yourself". So I'll Probably step up to a 325/50-20 Rear for the next set. Then I'll have a 33" tall tire with 12" of tread. Looks like I'm in desperate need of a traction device as well. Got to make some calls on that.
The Radix is performorming flawlessly. The first gates belt seems to be a defect as the replacement has held up just fine during my own version of "test and re-test" and haul freakin *** . Basically I'm operating it in its intended manner/purpose and the Radix is delivering the goods in spades I won't say I'm easy on things, nor am I hard on them.
Thats about it for now, I'll be mounting up my HPTuners/Jotto Desk combo tomorrow for some data logging and stuff.
Old Feb 1, 2005 | 09:06 PM
Breeze's Avatar
11 Second Truck Club
Sounds good man I beleive my Radix will be here tommorow (2/2/05) but wont be doing the install till the end of march cause I am taking the truck on a road trip to Jacksonville Fla but will install as soon as I get back.
Old Feb 1, 2005 | 09:07 PM
moregrip's Avatar
what a rush!
Congrats!
wheeeeeeeeeeeee!!!!!
Old Feb 1, 2005 | 09:09 PM
vanillagorilla's Avatar
Sounds good man! Isn't it cool when you finally find the problem and fix it. It's so much more rewarding that way.
Old Feb 1, 2005 | 09:30 PM
BlownChevy's Avatar
blownerator
25 Year Member
Uhhh he had a problem?
Old Feb 1, 2005 | 09:36 PM
Leroy_454's Avatar
Im very glad to see the radix has affected the tires that way!
Old Feb 1, 2005 | 09:56 PM
moregrip's Avatar
what a rush!
Thanks, no problems, just needed to re-torque the bolts as spec'd.
moregrip's Avatar
what a rush!
Me too!
Old Feb 1, 2005 | 11:12 PM
1Blown04's Avatar
Is this something that needs to be done or did you have a problem?
Old Feb 1, 2005 | 11:13 PM
moregrip's Avatar
what a rush!
Needs to be done after about a week or so. I just waited a little longer.
Usually takes several passes to get an EVEN 89inlbs.
