radix question
single digit dreamer
are the replacement injectors that come with the radix the small truck kind or did they swap them over to the bigger standard style?
if they are the small kind what is the minimum amount of space above the rail? looks like it might be the closest right under the TB. is there room to swap in the bigger injectors? probably need close to 1" of space. pic's of the space right under the TB would be awsume.
considering a radix set up with a fat shot of nitrous but i would need to be able to put in some big injecotrs for a dry shot or plumb it for a wet DP shot.
turbo/radix? turbo/radix? turbo/radix?...............................hmmmm
I don't really know if they are long or short they are Delphi 43lb. but there is plenty of room to fit a longer injector into the custom rails without interfering with anything.Call Magnacharger they will probably help you find the injectors you need and answer any questions you ask.805-289-0044
Its the Marine truck 8.1 injector. Same size and connector as all the other truck injectors.
I've got a couple ideas for the DP setup.
how much power in this combo? forged 408, 8.5-1, heads and cam, 100octane should be good for 12-15psi, 300shot DP with seperate fueling system and really good fuel.... hmm 900-1000rwhp? that should do it.
Take a look at the NX direct port nozzle system. ts pretty good, light years above the NOS brans kit. I think there is room for the DP under injector with the Radix fuel rail.
How do you plan on keeping 900-1000 HP in the chambers without blowing a head gasket? It seems like most BIG numbers engines with O-ringed heads and studs cant make that much HP.
, might just need it after i blow the thing up.
, might just need it after i blow the thing up. Vented the cooling system 3 seperate times on a C5R block with the heads TQ'ed to big #'s on my vette. 300 Direct port shot..
I did have a few high 9's and low 10's at 80-90mph when she blew though..
carid
Sep 10, 2015 09:07 AM
