Radix Guys Please Help Asap
You could have leaked oil to excessive crankcase pressure also. Usually your dipstick tube would have been pushed out slightly though or the oil filler cap would have popped off. Either way the guys are right, check your plugs regardless of what else you find. Putting on a smaller pulley almost always requires a retune to add fuel and or drop timing in certain places. If your plugs looked super white or are missing parts/slammed shut and the if you open the oil filler cap and have a choo choo train effect then you have troubles.
Hopefully we are all just jumping to conclusions and everything is fine.
Originally Posted by WaitinToDrag
i noticed an oil leak right behind the EGR, right where the blower meets the block it looks like. a buudy of mine said the knocking might be the cam hitting thie lifters without oil?
If you still have good oil pressure, then I don't think your buddy is right.
lxcoupe
Jul 21, 2015 02:12 AM
