Radix Guys, Please come in
Old Feb 23, 2005 | 11:34 PM
  #21
moregrip's Avatar
what a rush!
Originally Posted by j's01silverado
I have decided to go with a 3.25 pulley and an ALKY Control kit. 10 pounds will probably be a problem with the California 91 gas, and I dont want to have to run race gas.
I want to try to make the power by adding timing rather than running more boost. Meth injection will lower the IAT's and allow additional timing.
It's just wierd how people can run 10 pounds and have no problems, and my engine was knocking like crazy. struggling to make 300 rwhp!!!! I made 370rwhp with a 3.6 puley when dynoed at Magnacharger.
All in all, very frustrated. Not at anybody, just at myself for not knowing. I should have done more research and understood boost, but it is quite complicated. I will keep everybody updated.
370 with a 3.6
wowzers, I'll be lucky to make 370 with my 3.1
Old Feb 25, 2005 | 10:34 AM
  #22
Hawk179's Avatar
The inlet temps were actually close to 170 on most runs.
What people have to realize here is that 91 octane becomes unstable at a certain point. Yes you should have no problems in theory, but reality is not everyone gets away with it. As a tuner, the car/truck has to leave here safe, not cautious. The thing I noticed was with the smaller pulley, the blower was trying to make enough power that now his fuel system wouldnt keep up. So at the top, the injectors would cut back also. Sometimes I even saw a run or two where his pump just went down. At this point you can tell the setup is unstable. No need for that.
you will make more power on a setup like this with a larger pulley, running a cooler charge and a better amount of timing. The key is motor efficiency. Let me motor breath also without drownding it out.
Tuning boost is not rocket science, anyone can add timing and fuel at the right time. I could sit there all day and say I run more timing....but again I dont feel like buying someone a motor.
Rick
Old Feb 25, 2005 | 11:12 AM
  #23
BlownChevy's Avatar
blownerator
25 Year Member
Rick
Old Feb 25, 2005 | 12:30 PM
  #24
Flyer's Avatar
If the injectors show to be cutting back, I would think that the MAF is being maxed at that point. Once that happens, you need to start adding fuel other ways to compensate for that. Could that have been the problem?
Old Feb 25, 2005 | 12:59 PM
  #25
02Reaper's Avatar
Rick
It's nice to see a sponsor with an attitude like yours sir.
Old Feb 25, 2005 | 01:42 PM
  #26
BlownChevySS's Avatar
I am only seeing 8.5 psi with a 2.85 pulley! WTF?
Old Feb 25, 2005 | 01:44 PM
  #27
Hawk179's Avatar
you would tink so yes. But it was hard to tell what was happening, but you could feel the truck hold back power up top. Like if the charger wanted to try so hard, but had no where to move the charge, then it would hit 170 temps. At that point it dont matter about fuel or pumps, because you know there is no efficiency going on. So the best choice would be to ease back. I understand some people think it can be solved by tuning, or that someone may be able to tune better, but how comsidering the only alternative is to add timing or take out fuel if too rich, to which both are not the answer to stay away from knock. Plus there was a run where the fuel pump just couldnt keep up, so we stuck a gauge on it after that and watched closely. Couldnt get it to do it again, but it was scary enough the first time.
rick
  #28
Hawk179's Avatar
Your a 6.0L. You can move more out the exhaust.
Rick
Old Feb 25, 2005 | 02:00 PM
  #29
Hawk179's Avatar
Thank you very much.
Old Feb 25, 2005 | 02:36 PM
  #30
O3GMC's Avatar
12 Second Club
Rick
why would his IAT's be so high? people use 2.75 pullies on these things....are they just seeing insane IAT's? is the intercooler pump working properly?
