Radix Guys: How much boost???
Old Dec 1, 2004 | 05:49 PM
O3GMC's Avatar
12 Second Club
Stock airbox + K&N = 8.6 psi before the shift
I just ordered a 3.25 pulley to replace my 3.4, should see 9.5-10psi
Old Dec 1, 2004 | 10:35 PM
GMC_DUDE's Avatar
I get 7 to 7.5 psi boost with the stock 3.7" pulley. My engine is a 4.8 so it needs less air.
Old Dec 1, 2004 | 10:40 PM
Holy **** *****-maybe i should keep my stock air box and stick in a k&n. Thats awesome #'s. We need to meet up sometime so i can see this!!!!!!!
Old Dec 1, 2004 | 11:05 PM
O3GMC's Avatar
12 Second Club
Do you have the Joe Gibbs truck? Just curious what the 3.7 comes on, I thought the highest was 3.6
[edit - brian just told me the 4.8 kits come with the 3.7 ]
Old Dec 2, 2004 | 04:11 AM
GMC_DUDE's Avatar
No, mine isn't a Joe Gibbs, just an aftermarket unit I bought from Magnacharger. I read somewhere that the JG trucks have a 3.9" pulley, sort of an extra safety net for their warranty I guess. Also I heard that the pulley is mounted using a proprietary method so that regular aftermarket pulleys can't be used. However, modders, always an ingenious lot, found a way around it by just swapping out the whole drive snout. (Try and stop US from modding our truck will ya??!!! LOL).
Old Dec 2, 2004 | 05:13 PM
vortec327's Avatar
So having a cold air intake lowers the boost on a radix setup. I always thoght it raised the boost a little. Might have to find me a stock air box with a drop in K&N. What made you want to try the stock box?
Old Dec 2, 2004 | 05:18 PM
moregrip's Avatar
what a rush!
losing any boost in this scenario is not a big deal. It's still moving the same cfm and has a more dense Air charge to boot.
Old Dec 2, 2004 | 05:34 PM
Last Call's Avatar
TOTM: January 2007
I agree. An engine is a big air pump. A CAI will usually allow you to run more cfm through the supercharger because it uses a larger filter and is less restrictive. Moving less air at a faster rate is the same as moving less air at a slower rate. The amount of air does not change. However, a CAI usually allows a denser air charge like moregrip has stated.
There was also a thread awhile back about all boost being equal which most people disagreed with. They used the example of a big turbo at a certain psi and a small turbo at the same psi and how the cfm was different. Something like that I think.
Old Dec 2, 2004 | 05:44 PM
8ALTNG's Avatar
i used to see 10.5-11# with a 3.25 pulley.
SS94S10
Jan 3, 2019 01:57 PM
bagged7104SS
Sep 24, 2015 08:42 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
