Radix Guys: How much boost???
Old Jun 29, 2004 | 06:29 PM
Last Call's Avatar
TOTM: January 2007
Default Radix Guys: How much boost???
I got a radix on my truck and I usually see around 5-6 lbs at around 5800. I have to hold the gear manually to hit 7 lbs and it hits it only for a split second. How much boost are you guys seeing at or about redline?
Old Jun 29, 2004 | 06:41 PM
Mr. Sandog's Avatar
You should be getting 5.5 to 6 lbs with the stock 3.4" pulley across the RPM band. Boost shouldn't vary very much at all from 2000-6000 RPM's.
Old Jun 29, 2004 | 11:00 PM
tbyrne's Avatar
5.5-6# is correct. There are ways to get more though
Tom
Order line - 1-877-4-TBYRNE
E-mail - tbyrne@tbyrne.com
Price Match Plus policy
Old Jun 29, 2004 | 11:08 PM
BlownChevy's Avatar
blownerator
25 Year Member
That sounds about right.....should be about 5-6 psi on that motor.
Old Jun 29, 2004 | 11:24 PM
Flyer's Avatar
I htought it was 6-7 at redline.
Blown .. get on MSN plz
Old Jun 30, 2004 | 01:39 PM
Hoover87's Avatar
Damn, maybe my truck is gonna blow-up! I get 7 mashed on the floor and then when it shifts it winds up to around 8.
Old Nov 30, 2004 | 06:22 PM
O3GMC's Avatar
12 Second Club
sorta dug this up, but today I hit 7.9 psi w/the 3.4 pulley
I just put in the stock airbox w/K&N and holes cut in the bottom, going to see if that makes a difference.
Old Nov 30, 2004 | 06:23 PM
moregrip's Avatar
what a rush!
good idea, you dynoing it?
Old Nov 30, 2004 | 06:29 PM
O3GMC's Avatar
12 Second Club
No dyno, but I have a digital boost gauge (easy to read) so I'll be able to see any increase in boost, as well as throttle response
Old Nov 30, 2004 | 06:44 PM
dewmanshu's Avatar
Moderately Differentiated
I have a 3" pulley. 9.5lbs
Replaced Brake boost canister with a hydraboost system (brakes ran off of steering pump and fluid...well..the boost for the brakes) and now get up to 10.2lbs
Pulled trailer and a polaris 500 4x4 F-ing heavy 4 wheeler this weekend up we easterners call a mountain and the boost made it to 11.4lbs. Yeh scary...I think something is wrong, but I have some other issues I need to correct first.
