radix guys
Old Jul 22, 2003 | 09:06 PM
parish8's Avatar
single digit dreamer
Default radix guys
got a question for you, any chance this >> http://www.nitrousexpress.com/gallery.html would fit under the radix set up? looks to me like the blower wouldn't be a problem but the way the throttle body sits might be.
if anyone has a digital camera can i get a pic of the space between the throttle body and the stock injectors?
Old Jul 22, 2003 | 09:12 PM
Banned
Default Re: radix guys
it's starting to look like you have some kind of sick ideas in your head Jim
Old Jul 23, 2003 | 01:11 AM
Flyer's Avatar
I don't think it'll fit ...
Old Jul 23, 2003 | 01:12 AM
BlownChevy's Avatar
blownerator
25 Year Member
would not consider it....did you see teh vette in the FI thread?
Old Jul 23, 2003 | 06:31 AM
parish8's Avatar
thanks for the pic, i didn't realize the radix came with it's own fuel rail.
Old Jul 23, 2003 | 06:35 AM
parish8's Avatar
no guts no glory, he broke his because of a nitrous backfire, he was spraying thru the blower and i am prety sure he was spraying a wet ket. a DP setup doens't look to promising either.
Old Jul 23, 2003 | 07:58 AM
BigKID's Avatar
Is the intake on the radix made in such a way you could tap in your nozzles from the underside and run all you lines thru the valley? That would look cleaner and a lot more stelthy. But sure would be a pain if you had to change a jet.
edit: Nevermind, I forgot about the heat exchanger.
Old Jul 24, 2003 | 02:07 AM
Flyer's Avatar
In the install, they say if you have a certain harness (green plastic thing) on the block cover, that it has to be removed for the blower to fit.
The thing is huge and fills all the space available. When we installed mine, we were almost concerned that it wasn't going to fit under the hood.
Old Jul 24, 2003 | 03:17 PM
Parish 8,I think to Noszle kit from NOS would work,instead of replacement fuel rails they use an adaptor under each injector and a separate collection point for the solinoids,fuel and nitrous lines.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
