Radix Guys....
Old May 25, 2004 | 10:01 AM
Default Radix Guys....
Any of you guys using a JLP supercooler or powercooler? JLP Just wonder what kind of results you saw. Anyone running a similar setup?
Old May 25, 2004 | 10:15 AM
Flyer's Avatar
That thing is awfully high. I think David Cairns was using a JDM cooler. It looked real well and I think he said it ran better too.
Old May 25, 2004 | 10:57 AM
BlownChevy's Avatar
blownerator
25 Year Member
Gains will be negligible at best for the money. You have the upgraded set up don’t you? Fab up an e-fan set up for the H/E you have now, that will be money better spent.
Old May 25, 2004 | 02:23 PM
What Dave is running is actually just a bigger heat exchanger. This is a reservior fluid loop essentially that cools your fluid with ice or dry ice. This would only be good for the track, IMO, but if you manually pumped your fluid through this while in the staging lanes it could make a big diff.
Old May 25, 2004 | 02:45 PM
Flyer's Avatar
I've thought about using something like this and put it in the bed, the opnly problem is that I don't want to loose the functionality of the bed yet. If I ever put a tonnoeu cover on though a fuel cell and bettery is going in the very back, then a HUGE intercooler resevoir will be in the front of the bed.
Maybe something like a few small radiators in a tank filled with ice. I would probably get creative with the plumbing and put some valves on it so I could switch it from one to the other.
bagged7104SS
Sep 24, 2015 08:42 PM
therock
Jul 25, 2015 09:23 AM
sTNT971
Jul 16, 2015 12:39 PM
2003blue5.7
Oct 16, 2003 11:36 PM
DRaSTiK
11
Jun 5, 2003 07:14 PM
