coolant lines
whats the deal with the coolant lines on the top of the motor??? I saw a picture on a post that showed the little metal tubeing connecting the frount lines to the back. My truck "an 03" only has a line across the front. the back are blocked off.
I am in the middle of my ls6 create motor install and need to know if I need the lines that connect the frount with the back of the block..
Thanks guys....
Thanks guys....
no you are fine. alot of people like your setup better. O and if you are putting any type of long tube header on lay them in there as you drop the motor in it will make life a lot easier.
Good luck
Good luck
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
lxcoupe
Sep 25, 2015 12:36 PM
