View Poll Results: More Cubes or SuperCharge
LQ9 Swap including Cam (possibly Heads)
56.25%
Radix
43.75%
Voters: 48. You may not vote on this poll
Radix or Cubes-Which one to choose
Old Mar 31, 2006 | 05:28 PM
Matt@adams's Avatar
FormerVendor
I'd do the radix IMO, but if you were going to do the swap I'd say do the LQ4 so you have lower compression for BIG forced induction later.
Old Mar 31, 2006 | 06:46 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I'd be willing to help on the install as well, it's a piece of cake.
Careful, I might just take you up on that!
Old Mar 31, 2006 | 06:48 PM
Exclamation
Originally Posted by ap2002
I would go the radix route....
Your with stupid huh??? You are of with "stupid"!
He said go the 6.0L route. Your with him, but say go the Radix route!
Clear that statement up for us please!
If he wants to spend the money........ Y not do both!
Jim
Old Mar 31, 2006 | 06:49 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
If you get the radix plan on a cam swap to make the best of it.
Old Mar 31, 2006 | 06:50 PM
trever1t's Avatar
You dont think the 224 114 is a good cam for FI? What would you recommend?
Old Mar 31, 2006 | 06:55 PM
Post
Originally Posted by BlownChevy
Here is the way I see it:
If you want to go through the trouble of swapping in a 6.0 including all the supporting parts it will need then go for the 6.0. I dont see a quality 6.0 swap being done for less than 4500.00 (without the AFR heads) and about 2-5 days depending on your mechanical backround.
If you are looking to get about 120 rwhp gain, and spend about 5K and 9 hours installing it then go Radix.
personally I dont see a 6.0 truck making over 400 ft pounds at 2500 rpm.....and I certainly dont see you getting 120 rwhp over your 5.3 with the 6.0 swap.
let me know if I can help you out any further
On the getting more than 120 hp over the 5.3 statement. Allen told me he could do a heads, cam, and his tune and get me right at 500HP & 500 fT TQ at the rear wheels with my LQ9 6.0L. He also said it would have good idle and still use the stock injectors. Would just have to add an external fuel pump.
There are ways to get it done the N/A way still. You would just need the right combination of parts and quality tuning.
Jim
Old Mar 31, 2006 | 07:16 PM
F8L Z71's Avatar
Jim
Good luck with that. Its not likely unless you do an all out setup. most 408cid F-body guys rarely see over 500rwhp unless they good pretty big and with you being in a truck its not as easy as you make it sound. I've seen planty of N/A combos in F-bodys and 500rwhp is not an easy feat.
As for the stock injectors... LMAO
Old Mar 31, 2006 | 07:35 PM
ap2002's Avatar
hey Jim (CHEVY6000VHO) I think I got it right this time...
I really thought you'll get that rwhp n/a, but I wont argue with you cause I know you are alot knowledgable than me...
Old Mar 31, 2006 | 07:40 PM
dewmanshu's Avatar
Moderately Differentiated
Jim
Allen said 500 with stock injectors?!?!?!?
Old Mar 31, 2006 | 07:50 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Do the radix. You said yourself you've always wanted boost...
I don't believe a 6.0L is going to hit 500/500 without FI (or maybe 13:1 compression) and no way on 26lb injectors.
