Race Wheels
Old Dec 30, 2004 | 12:26 PM
Scream's Avatar
MOOBIES Moderator
Yeah, since you have a 4 link, why not narrow the rear end, get some axles made in 5 lug, and convert the rear to OBS drums and run 15s all day long? I dunno, just throwing ideas out there...
Old Dec 30, 2004 | 12:29 PM
XLR8NSS's Avatar
Adkoonerstrator
Do THIS!!!!
Old Dec 30, 2004 | 01:58 PM
2toneblown's Avatar
I am going to. I have a 9 inch being built right now, but i dont want to convert to 5 lug cause already have 3 sets of wheels for my truck so am having custom axles made with 6 lug and its getting tubbed also. But i want some wheels that will work now cause im going to try and take it to the track next weekend and i want to run the 29.5s and not the 28s
Old Dec 30, 2004 | 02:19 PM
why dont you get a set of billet wheels like budnik, intro or billet specialties. They will make any backspacing you need.
Old Dec 30, 2004 | 05:36 PM
parish8's Avatar
single digit dreamer
i got one centerline wheel custom made, it was prety cheap, something like $140 i think. it is a 15x10 with a 5.5" bs. it isn't even close to fiting. i tried 1" of washers behind it so prety much a 4.5"bs and then did about an hour worth of grinding and it still didn't fit.
i would love it if someone found a way to get 15x10's on these trucks and not have them stick out a mile. 15" tires would kick ***, soo many options there.
Old Dec 30, 2004 | 06:25 PM
GMC SKI's Avatar
Rear drums from an 05 sounds like it might be a plan
anyone out there that can measure them up for us?
Old Dec 30, 2004 | 06:34 PM
2toneblown's Avatar
grey silver got a 15x9 under his which that looks like thats what im gonna have to do.
Old Dec 30, 2004 | 07:25 PM
L-EATER's Avatar
11 Second Truck Club
I have 15x10 steel white spokes and they hang way out and look really crappy. I had to grind about an hour on the calipers to get them to fit. Aluminum wheels are generally thicker (smaller ID on the part that goes over the brakes) so I think it would be really hard to get them to fit over the stock brakes. The drum conversion sounds promising. I am going the opposite direction this season-gonna use a 16 inch wheel and the 28 inch Hoosiers.
Old Dec 30, 2004 | 08:36 PM
Grey Silver's Avatar
11 Second Club
Originally Posted by 2toneblown
any help?
I've been working too much. look here http://www.eaglewheels.com/index.htm They've got all the specs listed including b/c, offset, and weight. I run 15x7 on the front and they just bolt on, 15x8 on the back. I ground the calipers on the back and relocated them by slotting the mounting holes on the calipers about .100", that dropped them down enough to clear but the clips were rubbing on the outside diameter of the rotors so I turned them down a little. Discount tire helped me figure out the back spacing, my slicks are even w/ the truck. 15x10 might stick out a little but I think drag lite will build custom wheels if you got the $.
Old Dec 30, 2004 | 10:27 PM
vanillagorilla's Avatar
Do you have any pics of this? When you say the fronts bolt on, do you mean just that? No grinding or anything?
Gadgetized
Aug 21, 2020 03:14 PM
5.3Caprice
Nov 7, 2015 08:56 PM
thunder550
Oct 8, 2015 04:53 PM
WhoAteMySoup
Aug 20, 2015 09:52 AM
