A quick yes or no will do....
Old Jul 1, 2006 | 08:11 PM
RU55ELL's Avatar
Default A quick yes or no will do....
I assume it would, but will a K&N FIPK off of an 03 silvy fit my 06? Same size motors and everything.
Old Jul 1, 2006 | 08:15 PM
getchusum99's Avatar
yes it will
Old Jul 1, 2006 | 09:36 PM
v8
17,16,15,14,13,12,11 Drvr
Yes!!!!!
Old Jul 1, 2006 | 10:37 PM
COLDZ71's Avatar
I thought the 03s had the clutch fan with the smaller radiator and the 05 and up had the electric fan with the larger radiatior? The heat shield wouldnt fit quite right then would it?
Old Jul 1, 2006 | 10:41 PM
No it will not. The 06 has a larger radiator and e-fans. They use two completely different mounting locations. The pre-05's have a sort of angled shape (heat box), while the 05+ have a completely squared off heat box.
Old Jul 1, 2006 | 10:53 PM
SSlow 4.8's Avatar
you are correct sir
Old Jul 2, 2006 | 12:16 AM
gmtechnician's Avatar
this is true i tried to fit the FIPK from my 01 to my 06 and it would not fit. the heat shield is to big.
Old Jul 2, 2006 | 12:45 AM
TouchOfEvil04's Avatar
Big deal.....cut that **** mang!!!!
Old Jul 2, 2006 | 08:06 AM
tdrumm's Avatar
Yeah, when I swapped in the 34" radiator and 05 fans, I had to modify the K&N box. Nothing 15 minutes with a cut off wheel and hammer couldn't remedy.
Old Jul 2, 2006 | 12:33 PM
RU55ELL's Avatar
Dang, well no big deal then. I got a buddy that just traded his 03 silvy for a 06 Magnum R/T. He was gonna give me the FIPK. He also has a Hypertech programmer but I knew that wouldnt work on mine for sure. Anyways thanks for the replies.
