quick questions
Old May 16, 2006 | 01:31 PM
Tweek5.3's Avatar
Default quick questions
I just had a couple of quick questions. Does anyone know the increase in hp or torque from doing a tb spacer and e-fans mod and also how much of and increase would a zo6 intake manifold do if anything?
thanks
Old May 16, 2006 | 02:32 PM
Beastofa327's Avatar
Depending on the company they should state the increase in HP&TQ and most times thats at the crank. But from what I read a TB Space is about 5 hp and E-fans about 17-20 hp depending on the size and the LS6 or ZO6 intake thats a good Question??? I don't know whats Mods would you have to do to make it work but If it did I think I read it's about 30 hp
Old May 16, 2006 | 02:47 PM
Quik's Avatar
5 year bitches!
unless you are a higher reving motor you dont need the LS6. i do personally have it. i just made my truck motor a car setup. there are ways of making it work i chose this way. easiest and cheapest for me
but it is time consuming to make the wiring harness nice and neat
Old May 16, 2006 | 03:50 PM
Gran Patron's Avatar
Like Quick mentioned, the LS6 intake wont do anything positive on your stock motor the stock truck intake is just as good. For as the TB spacer wont to anything in performance gains. The efans bring about 5-10HP at best.
Old May 16, 2006 | 04:03 PM
EvilChevy's Avatar
From what i understood from Texas Speed And Performance , The truck intake flows better than the LS6 intake i could be wrong but i believe that's what they told me. Also TB spacers are kind of a ghost mod, They work for some not for all..
Old May 16, 2006 | 08:07 PM
v8
17,16,15,14,13,12,11 Drvr
I put one on the dyno and lost 1hp and gained 1lb of tq, fans not sure. but in the heat imo 20 hp in the cold 2hp.
Old May 16, 2006 | 10:32 PM
the truck intake does not flow nearly as well as the LS6 manifold especially when approaching 6000 rpm, you run out of air
Justin87gn
Sep 10, 2015 12:06 PM
custm2500
Sep 8, 2015 05:53 PM
bisqikss
Sep 8, 2015 03:35 AM
SWINGRRRR
Sep 3, 2015 07:49 PM
mr03silverado
Sep 2, 2015 11:43 PM
