Questions about building a 6.0 stroker w/ Radix
Old Jul 4, 2003 | 09:06 PM
parish8's Avatar
single digit dreamer
Default Re: Questions about building a 6.0 stroker w/ Radix
The Radix flows better than you give it credit for!
lets hear some numbers! i am not saying it wont do a fantastic job on a 5.3 or even a 6.0 but i have my doubts it will feed a 408 with enuff air to be worth making a 408.
Old Jul 4, 2003 | 09:14 PM
BlownChevy's Avatar
blownerator
25 Year Member
I will find out more info for you on monday.....E-mail me to remind me ! bzacuto@socal.rr.com
Old Jul 4, 2003 | 09:27 PM
Big Tex just said in another post that he saw an SS Silverado with a 427 and a Radix, and it had no problem.
Old Jul 4, 2003 | 09:28 PM
The radix system for a 5.3 uses a 3.4"pulley to make 61/2lb of boost the 6.0 makes the same boost with a 3.2"pulley.A 408 would make about 61/2lb boost with a 3.0"pulley like I am currently running.With a 3.0"pulley my Tahoe makes 91/2lb of boost when I open the throttle but the boost is still climbing at the 6000rpm rev limiter showing 11lb.Ford Lightnings using the same supercharger have no trouble maintaning 13lb of boost.And I've seen pulleys that fit a Radix as small as 2.3".
Old Jul 4, 2003 | 09:35 PM
BlownChevy's Avatar
blownerator
25 Year Member
and you have to remember that the lighting blower is the old 112, the radix uses the new MP112.
Old Jul 4, 2003 | 10:42 PM
parish8's Avatar
ok guys, i am not trying to slam the radix at all, it looks to be the best system out there right now to me.
the question is will it feed alot of boost into a stroker motor. if your going to build a forged stroker motor i hope you are going for some BIG numbers, otherwise why bother with a stroker, just beef up the 6.0 a little. how much boost is the 427 that big tex mentioned seeing?
another thing, if the 112 refers to the cubic inch displacement of that blower than it is smaller than the whipple. 112ci = ~1.9L, that is alot smaller than the 2.3L whipple and the whipple would never efectively feed a 408 unless you are going to be happy with 6-8psi.
i would love to be proven wrong, i am looking at doing a turbo set up but if there was a big intercooled roots or twin screw blower out there for us i would go that route. a low compresion 408 with 14lb's of boost would be crazy :-)
the lightning guys are runing a 5.4 right? not a 7.0. and they upgrade the blower when they really push it too.
Old Jul 4, 2003 | 11:03 PM
Parish8 if I were building a 10second street truck I would use the Radix intake manifold and intercooler with the intercooler modified to run off the airconditioner compresser and 2-2.3liter whipplechargers with 2 electronic throttlebodies and MAFs sitting on top of a 427 stroker.1100HP with a 5200lb truck would easily put you into the low 10s.You could make enough boost and flow enough boosted mixture to make more than 1400hp.
Old Jul 5, 2003 | 12:38 AM
Banned
if i were building a 10 second blown 408 i'd put a d1-sc or an F1 on it and boost the **** outta it.
USMCvet0311
Aug 14, 2015 10:28 PM
USMCvet0311
Aug 1, 2015 07:45 AM
therock
Jul 25, 2015 09:23 AM
justuc
Jul 24, 2015 11:52 PM
Suburban2500
Jul 19, 2015 04:50 PM
