questions
Old Dec 5, 2005 | 08:25 PM
  #21
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Yuip you sure can just use your tb. EVERYTHING will swithc over I mean everything external. Get you a nice low mileage LQ9 that you wont have to rebuild throw a tr224 cam in it which is mild for a 6L put a trailblazer stall in the trans and run 13s in your truck but still get good mileage and have great around town drivability.
Old Dec 5, 2005 | 08:30 PM
  #22
1slow01Z71's Avatar
Yes you can run an 03 LQ9 but you have to use your intake cause the 99-02 have a return line 03-05 are returnless. You can use your cable tb on the 03 eninge like I said use your intake you have now on the 6L. Put a tr224 cam in it with a trailblazer stall in the trans with a vette servo transgo HD-2 hift kit remove 80% TM and have a DD with great highway mileage with 60-70 hp increase over the 5.3 and run 13s in an ecsb Z71. Now if only I would have went that easy route
Old Dec 5, 2005 | 08:31 PM
  #23
1slow01Z71's Avatar
Damn pt.net server it said there was an error so I thought my post didnt go thorugh but it did Anywho basically said the same thing in both posts.
Old Dec 5, 2005 | 08:35 PM
  #24
stone150's Avatar
thanks, i think when or hopfully do this i will get a new power steering pump too, man i am going to spurge! i thought i red some where that i had to have a adapter for the 4l60e tranny to bolt up to the 6.0l? also what if it comes with a computer, and it is a 03+ can i use it or just have mine re flashed?
Old Dec 5, 2005 | 08:42 PM
  #25
1slow01Z71's Avatar
Use your computer get it tuned for the 6L. Get Allen Nelson to do it he knows his ****. No adapter needed t get the 6L to bolt up to the 60e. Definately do what I was saying to the trans to make it last if you beat on it at all.
Old Dec 5, 2005 | 09:43 PM
  #26
stone150's Avatar
ok sweet, ok i know i am getting bothersome but how hard it the physical swap? thanks again
Old Dec 5, 2005 | 10:10 PM
  #27
1slow01Z71's Avatar
NOt that hard will take you and a buddy probably all day topull and reinstall Im talkin hard work from 8 in the morning till midnight. Took me and mjhoward about 6-7 hours to pull the motor out of my truck.
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
