questions
Old Nov 22, 2005 | 09:59 PM
stone150's Avatar
Default questions
ok i have a couple questions that have beeen bothering me.
if you swap a 6.0l can you use the stock harness and computer and everthing else?
what makes more power, stock 6.0l lq9 or a non intercooled radix 5.3l?
Old Nov 22, 2005 | 10:09 PM
Rhino79's Avatar
9 Second Club
Yes you can use the existing electronics and the Radix 5.3 would definetly be stronger.
Old Nov 23, 2005 | 01:32 AM
stone150's Avatar
thank you that is what i wanted to know.
Old Nov 23, 2005 | 04:19 AM
dkubricht's Avatar
get the 6.0L and then the radix to make more power!!!
Old Nov 23, 2005 | 08:30 AM
budhayes3's Avatar
PT's Slowest Truck
You can use the stock 5.3 computer, but you need to get it retuned to accomodate the different volumetric effeciency of having .7 more cubes. It will run with the 5.3 tune, just not well.
Old Nov 23, 2005 | 09:00 AM
thunder550's Avatar
High on diesel fumes
This is my plan! I just bought the first piece of my LQ9 from grippy, and I am planning on swapping everything I can over from the 5.3
Old Nov 23, 2005 | 02:43 PM
stone150's Avatar
have 2 more questions:
if i remove TM with nelson tune will it mess up my tranny?
if i remove the EGR with the nelson tune, will i pass emissions?
Old Nov 23, 2005 | 05:01 PM
Gran Patron's Avatar
It all depends on how much TM you want to remove! Some peeps go all the way on remove 100% of TM and their stock trannys of held up. Other members, like me, would recommend to remove like 80% of TM removed so the tranny can hold up. But just get servos and a HD Transgo kit and that should help the tranny out for a while. You should get different answers from other members.
Yes, I belive removing the EGR should be no problem with emmissions!
Old Dec 4, 2005 | 01:29 AM
stone150's Avatar
ok came up with more questions, i am now thinking about buying and rebuilding a LQ9 next summer. are all the parts except the internals interchangable with the 5.3l. how is the gas millege? is it a direct swap or will i need something else for the tranny and will it blow up my tranny?
Old Dec 4, 2005 | 06:35 AM
Jethro_3's Avatar
Texas Emissions test is done through the OBDII for those that have it. They hook it up and if they do not see any codes you get your sticker. Some things can be shutoff and then the emissions test will not see them. Just watch for the white vans on the side of the road, do a shut down coast through if you know you aren't passing
Let me get this right, you are asking about MPG on a performance sight????? Jokes aside, with just a Nelson Hot Tune and keeping the foot out of it I could/can get close to 18hwy.
