Questionable setup?
Old Jan 13, 2005 | 01:32 PM
zippy's Avatar
i'd be looking at a 6.0L over the 5.7 personally.
6.0L
LS6 heads
Rossler Trans
4.10 gear
Detroit locker
3000 Vigilante
Old Jan 13, 2005 | 01:55 PM
TigerFan187's Avatar
If you wanted n20 ad enough just get the NX intercooler setup. Im not saying 4l65e wouldnt work but if I was to do that setup I would spend the extra $ and do the 4l80e and be done with it!
Old Jan 13, 2005 | 02:21 PM
parish8's Avatar
single digit dreamer
the nx intercooler set up wouldn't do a whole lot on an air to water set up. you would get a lot more out of it by just spraying it into the motor.
Old Jan 13, 2005 | 02:48 PM
Zippy - A 6.0 would be cheaper, but a LS6 weighs a little less, ~80lbs is what I have heard. But a 6.0 would be stronger.
As far as the 4L80e, how much harder is it to swap? Cost diff? Powerloss through drive train? < should I start a new post?
Old Jan 13, 2005 | 02:53 PM
Difference between the two would be 65lbs. The 6.0 block would be stronger, but you could put a stock LQ4 with upgraded studs and bolts, and run on that truck all day. It would be a bit cheaper too. Both would be good choices.
GXPJAY
Feb 13, 2022 08:15 AM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
